what do i do now :-/
Old Apr 17, 2006 | 07:01 AM
vlc92189's Avatar
Default what do i do now :-/
ok i hooked up the whole wiring kit.. subs a\nd amp./. but when i have all fuses in.. and turn the car on either the fuses in the amp blow... ( 30A) fuses.. or the main fuse blows that came with the wiring kit... can that be a bad amp or what?
Old Apr 17, 2006 | 07:49 AM
B18C_EJ8's Avatar
Are you sure you have the power wire to the + terminal and the ground wire to the - terminal??
How are the speaker wires connected? What happens if you don't hook up the speaker wires to the amp? Do the fuses still blow then?
Old Apr 17, 2006 | 08:06 AM
vlc92189's Avatar
i have the power wirte to the + terminal.... and as for the ground.. its grounded to the back right sturt mount.. that's located inside the trunk.... and i cant tell because i gotat get mroe fuses...
Old Apr 17, 2006 | 12:30 PM
fcm's Avatar
fcm
Old Fart
Default Re: (vlc92189)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vlc92189 &raquo;</TD></TR><TR><TD CLASS="quote">i have the power wirte to the + terminal.... and as for the ground.. its grounded to the back right sturt mount.. that's located inside the trunk.... and i cant tell because i gotat get mroe fuses...</TD></TR></TABLE> I think B18C_EJ8 meant are you sure the power and ground on the amp are connected to the proper terminals.
What size is the fuse on the power cable, [by the batt.?
What gauge is the power cable/kit?
What is the make/model of the amp?
Once you get the fuses try what B18C_EJ8 suggests, disconnect the speakers from the amp and try, [I would also unplug the RCAs] and see what happens, if the power and ground are connected properly on the amp and the RCAs and speakers are disconnected and the fuse still blows, the problem is in the amp, more then likely blown outputs.
logeywartooth
Audio / Security / Video
Sep 16, 2008 12:19 AM
Skitals
18
Sep 16, 2003 08:27 PM
Understeer
Aug 23, 2002 03:04 PM
Bklyn TSi
Nov 6, 2001 11:11 AM
BoroDB8
Oct 15, 2001 01:09 AM
