What amp should I get
Old Sep 1, 2004 | 12:33 PM
nixadm's Avatar
Default What amp should I get
asdasdf
Old Sep 2, 2004 | 05:24 AM
nixadm's Avatar
Default Re: What amp should I get (nixadm)
asdasdf
Old Sep 2, 2004 | 03:14 PM
Goatsterrman's Avatar
You really need to let us know if they are w6's or not and also what ohm load they are. That info is imparative as to what amp you should use.
Old Sep 4, 2004 | 10:44 AM
BeanBag64's Avatar
Default Re: What amp should I get (Goatsterrman)
Get a JL amp just to match with the subs
Old Sep 8, 2004 | 03:54 AM
dont_hate_da_playa's Avatar
i have a performance technique....1200 watt amp....it's not bad for only $140. it powered 2 of my 12" subs....i'm sure if u paid a lil more for a 4 channel it would be fine. it all depends on if ur on a tight budget....u could always ask a local car/audio store person too.
Old Sep 9, 2004 | 08:00 AM
milton's Avatar
Default Re: What amp should I get (dont_hate_da_playa)
get brand name ****... wtf is perfromance watever.. go with jl amp or kicker kx1200.1 if ur running a 1 ohm load i suggest that one.
Old Sep 9, 2004 | 08:38 AM
lunchboxEF91's Avatar
performance technique is not such a bad name i've heard/seen a few PT setups and they sound pretty good but for the amp i would go with the JBL 1200.1 best bang for buck!
Old Sep 9, 2004 | 10:10 AM
iloveht
Guest
Posts: n/a
Default Re: (lunchboxEF91)
what version W6 is it? memphis amps or MMATS amps own.
Old Sep 10, 2004 | 11:59 AM
.brian.'s Avatar
i know what you should run...A JL 1000/1...And what a coincidence, I have one! For real though, I love JL amps. Look at running 2 500/1's!
Old Sep 10, 2004 | 12:52 PM
SirRevvs's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nixadm &raquo;</TD></TR><TR><TD CLASS="quote">Need some advice on an affordable amp..
I currently have 4 10" JL w6's (i think w6's) homemade box....
maybe this is your problem did you build it?
Old Sep 14, 2004 | 04:36 AM
Default Re: What amp should I get (SirRevvs)
yea definitely....prolly ur homeade box....what'd u build it out of?
Old Sep 14, 2004 | 04:38 AM
Default Re: What amp should I get (milton)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by milton &raquo;</TD></TR><TR><TD CLASS="quote">get brand name ****... wtf is perfromance watever.. go with jl amp or kicker kx1200.1 if ur running a 1 ohm load i suggest that one.</TD></TR></TABLE>
Performance Technique isn't bad....it's prolly not the top-of-the-line tho....if u want something that works...it's all rite. i liked it cuz it also came w/ the new control where u can control the amp from the front of the car.
Old Sep 26, 2004 | 04:31 AM
nixadm's Avatar
Alright...sorry I took so long.. the speakers are JL 10" W1-8.. which I guess are less than W6's.. Just got rid of the box, what kinda box do you guys suggest? max watt for these speakers is 125... so I should get a 500 watt amp? I currently have a dei 2504.. 50x4, 80x4
According to: http://members.fortunecity.com...e.htm these are 8 ohm?
Modified by nixadm at 2:50 PM 9/26/2004
Old Sep 26, 2004 | 06:23 AM
nixadm's Avatar
Is there a big difference between these?
http://cgi.ebay.com/ws/eBayISA...&rd=1
http://cgi.ebay.com/ws/eBayISA...=WDVW
the sony just seems alot cheaper
Old Sep 27, 2004 | 08:48 AM
.brian.'s Avatar
Default Re: (nixadm)
Just like everthing else, you get what you pay for. The JL amps are great because of the fact that they run the power from 11-14.5V, not just 14.4 like most amps. IMO I'd go with the JL
Old Sep 27, 2004 | 10:49 AM
C-West Civic's Avatar
Default Re: (i luv my 97 teg)
Go JL and if you dont mind used, they can be found for 200 - 250, which I did and it works fine.
///Nick
Audio / Security / Video
May 3, 2011 11:19 AM
lsvtek
42
Feb 11, 2007 09:55 PM
Orpheus1985
Jul 21, 2005 07:15 AM
JohnnyLux
Dec 14, 2004 09:27 PM
LuDeS
Nov 23, 2001 06:07 PM
