amp sub install
Old Apr 18, 2004 | 10:17 PM
newbie_on_the_doobie's Avatar
Default amp sub install
Hi i drive a 2004 civic se and i was wondering if i could hook up an amp to my stock deck? And if so how do i get the deck out ?
Old Apr 18, 2004 | 10:24 PM
TnTWRX's Avatar
Default Re: amp sub install (newbie_on_the_doobie)
You should just be able to use a universal speaker-to-line level convertor to hookup the amp to your factory stereo
here are a couple:
http://www.sounddomain.com/sku/SCOFAI3
http://www.sounddomain.com/sku/STISALOC
http://www.sounddomain.com/sku/PERVEN4
Old Apr 18, 2004 | 10:37 PM
Default Re: amp sub install (TnTGSR)
what about the remote power cable is it on the deck?
Old Apr 18, 2004 | 10:59 PM
TnTWRX's Avatar
Connect the amplifier's remote wire to a switched (accessory) +12 volt source. This is the same type of power source your radio uses. Now when you turn the car on the amp will turn on and when you turn the car off your amp will turn off. No worrying about your battery draining because you forgot to turn off your amplifier (and you will forget). Don't connect it to the power antenna lead. This only provides a turn on signal with the radio. The amp will not work if you use a CD/tape source
I sourced this from Sounddomain.com. (just wanted to give credit where credit is ude)
rountreesj
Audio / Security / Video
Dec 18, 2012 06:51 PM
user 996328629
14
Feb 24, 2009 12:29 PM
pdpjr
Jan 17, 2009 12:42 PM
.Thomas
Jul 26, 2008 03:40 PM
JdM_RACeR07
Nov 19, 2006 04:02 PM
