voltage??
Old Sep 20, 2006 | 07:09 PM
Casey's Avatar
Default voltage??
How many volts should the constant and ignition be sending to the head unit?
I checked mine with a DMM and got 14 for constant and 4.5 for ignition. Reason I ask is my head unit is not working and Im trying to track down the problem, seeing as it didnt occur until i pulled the head unit out to put a DIN cage in, thanks
Old Sep 20, 2006 | 07:28 PM
94_DC4's Avatar
Default Re: voltage?? (Casey)
Should be 12~14 volts depending on whether the car is running or not. Check the fuses under the dash and the fuses under the hood. Should be a 7.5A fuse.
itsrooster
Honda Civic (2001 - 2005)
Jan 7, 2013 03:49 PM
BIG SHAFE
Audio / Security / Video
Jan 24, 2005 07:46 AM
subcons
Mar 26, 2003 07:08 AM
4doorturbo
Feb 4, 2003 12:25 PM
4doorRS5spd
Aug 17, 2002 08:31 PM
