Viper 791xv (process of installing)
Old Sep 24, 2006 | 08:16 PM
Jdmglenn's Avatar
Default Viper 791xv (process of installing)
So far i just wanna hook up the alarm so the basic functions work. Power, ground, door trigers, and lights are hooked up and working.
BUT i hooked up the hoodpin switch and it doesnt seem to be working.... HELP?
Ive installed other alarms before but this one by far is the most complicated. I also noticed most alarms had a YELLOW wire for the (+) ignition switch but this one doesnt. So my blue led is always blinking.
Old Sep 24, 2006 | 08:45 PM
94_DC4's Avatar
Default Re: Viper 791xv (JdmGlenn)
Did you connect the hood pin wire to the blue wire on the harness?
Old Sep 24, 2006 | 09:22 PM
Jdmglenn's Avatar
blue? in the manual it says to connect it to the grey wire in the H3 harness which is what i did but it doenst sound the alarm when i pop the hood.
thanks
Old Sep 24, 2006 | 11:44 PM
skrewdriver88's Avatar
Default Re: (JdmGlenn)
if i rember correct it is the blue wire
Old Sep 25, 2006 | 07:58 AM
Jdmglenn's Avatar
it says in the manual that the Blue wire is the (-) multiplex input for zone 4.
Thats for like hooking up another sensor isnt it?
Old Sep 25, 2006 | 09:34 AM
wrx-killer-Sti-eater's Avatar
From: 99 probs but a stolen car aint 1, ca, cerritos/fullerton
pmed, to lazy to type
Old Sep 25, 2006 | 10:22 AM
Jdmglenn's Avatar
Default Re: (wrx-killer-Sti eater)
Ok cool thanks man, I'm at work as we speak but I get off around 530 pacific time
Old Sep 26, 2006 | 08:50 AM
Jdmglenn's Avatar
bump i will try to call today, i have a hectic schedule
Old Sep 26, 2006 | 12:18 PM
This is what you should try. Make sure the hood pin is grounded properly. Arm the car wait 15 sec then ground the hood pin wire. If it goes off check the pin. If you are doing this before the 15 sec the alarm never had a chance to check all of its zones and it by-passed the hood pin. Also you need to hook up the pink wire off the remote start harness. The alarm might also bypass the hood pin if it was triggered to many times. And need to be reset by turning the ingintion on. But the alarm doesn't know when to reset because the wire is not hooked up. This is called nusiance protection. This keeps your car from being towed because the law can have it towed if you arm is causing havik or going off to many times in one period. This also bypasses a faulty zone.
Old Sep 28, 2006 | 09:24 AM
Jdmglenn's Avatar
thanks Wrx-killer-sti-eater. Most of the alarm is working properly now. Next is to install the remote start satellite and the power locks..
bump
Old Sep 28, 2006 | 09:27 AM
no problem, if you have any other problems just post them and we will try to get you on your way!
Old Oct 1, 2006 | 09:02 PM
Jdmglenn's Avatar
bump once again haha
ok today i installed the dual stage prox sensor but it doesnt seem to be working right. The green and red lights work and all but no sound.
Old Oct 1, 2006 | 09:07 PM
Jdmglenn's Avatar
this is how i wired it
Old Oct 1, 2006 | 09:19 PM
fcm's Avatar
fcm
Old Fart
Oops, you didn't read your install guide, the dual stage prox sensors blue and green wires should both be connected to the blue (-) multiplexed input, zone 4, of the alarm brain, in the pix it looks like you have it connected to the impact sensor wiring. 94
Old Oct 1, 2006 | 09:26 PM
Jdmglenn's Avatar
ohhh, so it is to the blue one. In the back of the install guide it says the blue one is for the trunk trigger. So i hooked it up to the trunk trigger.
So if i hook the blue and green wire to the blue one. itll work ?
Old Oct 1, 2006 | 10:03 PM
fcm's Avatar
fcm
Old Fart
It can be used for any neg. (-) trigger, but because it is multiplexed it can trigger warning or full alarm, so use it for the dual stage prox sensor, connect the trunk to the hood pin input, it will mean trunk/hatch light will come on when you open the hood, [unless a diode is installed] no biggie, and remote start will not work with trunk/hatch open, just like it will not if hood is open.
You could connect both the trunk/hatch and the prox sensor to the blue wire, install 2 diodes one on the trunk/hatch line and one on the blue and green lines from the prox sensor then connect them to the blue wire,
One more thing, make sure there are no wires above the prox sensor, in fact, there should be no metal of any kind above the sensor 94
Old Oct 2, 2006 | 07:37 AM
Jdmglenn's Avatar
Default Re: (fcm)
Would this be correct? if so what kind of diodes should I buy? thansk in advance
Old Oct 2, 2006 | 08:05 AM
fcm's Avatar
fcm
Old Fart
Yes that would be correct, the only thing now is the "direction" of the diode, make sure cathode, [end with white band] is on the sensor side and the anode end is the one you connect to the blue wire. 94
Old Oct 2, 2006 | 09:05 AM
Jdmglenn's Avatar
thank you FCM , i will try this today after work
Old Oct 28, 2006 | 07:04 PM
Jdmglenn's Avatar
Default Re: (Jdmglenn)
Modified by Jdmglenn at 7:39 PM 10/29/2006
Old Oct 29, 2006 | 02:07 AM
mv1luv's Avatar
should be 1 adjustment screws on top side of box. 1 adjustment screw is for sensitivity between warning chirp and alarm trigger.
Old Oct 29, 2006 | 09:40 AM
Jdmglenn's Avatar
Default Re: (mv1luv)
Modified by Jdmglenn at 7:40 PM 10/29/2006
dacohns7267
Mar 28, 2011 09:40 AM
nocturnal EG
Audio / Security / Video
16
Nov 3, 2006 08:04 AM
jisu009
Feb 2, 2005 06:03 PM
allmotorEG-SI
Dec 22, 2003 04:37 PM
Civic Type-R
May 14, 2003 03:07 PM
