Viper 5002 … H1 Primary Harness help?
1998 Honda Civic EX Sedan 5-Speed
Viper 5002 alarm system
Hello,
Thia is what I have so far...any help would be appreciated!!
H1 Primary Harness
H1/1 RED/WHITE (-) 200 mA Channel 2 Output
H1/2 RED (+) Constant 12V Power Input (15A fused)
H1/3 BROWN (+) Siren Output
H1/4 YELLOW (+) Switched Ignition Input, Zone 5
H1/5 BLACK (-) Chassis Ground Input
H1/6 VIOLET (+) Door Trigger Input, Zone 3
H1/7 BLUE (-) Instant Trigger Input (trunk input/shunt), Zone 1
H1/8 GREEN (-) Door Trigger Input, Zone 3
H1/9 BLACK/WHITE Domelight Supervision Relay Output #30
H1/10 WHITE/BLUE (-) 200 mA Channel 3 Programmable Output
H1/11 WHITE (+)/(-) Selectable Light Flash Output
H1/12 ORANGE (-) 500 mA Ground-When-Armed Output
H1/1 - ??
H1/2 - to 520T GRAY (15A fuse on Viper side)
H1/3 - to 2 Sirens, split wires, and place a 1A fuse on the one under hood to protect from grounding.
H1/4 - ??
H1/5 - GROUND
H1/6 - NOT USED
H1/7 - to Trunk BLUE/BLACK
H1/8 - JOIN with H1/9 to (door trigger = light green/red (-)
H1/9 - JOIN with H1/8 to (door trigger = light green/red (-)
H1/10 - NOT USED
H1/11 - ??
H1/12 - ??
Thank you for any help!
Hello,
H1 Primary Harness
H1/1 - ??
H1/4 - ??
H1/5 - GROUND
H1/6 - NOT USED
H1/10 - NOT USED
H1/11 - ??
H1/12 - ??
Re: Viper 5002 … H1 Primary Harness help?
I have seen the one for the 98 Civic, but I'm unclear about and where they go to on the 98 Civic:
Thanks.
Matt93eg
Audio / Security / Video
13
01-11-2010 08:24 AM
