tweeter/crossover question
Old Nov 10, 2009 | 05:10 PM
beav's Avatar
Default tweeter/crossover question
hey guys, i have a jvc head unit and i just picked up a component set for the front and a set of 2-ways for the rear.
i do not plan on connecting a whole system, i just want the HU and speakers (ran through the stock wiring)
my question is...do i need to use the crossover or will the tweeters get blown if i dont?
and if i do use the crossovers, do they need to be connected to an amp? cuz i dont have/want an amp.
Old Nov 10, 2009 | 05:29 PM
jdmferioej6's Avatar
Default Re: tweeter/crossover question
you can run it off the stock stereo...its best to use the crossovers you dont need a amp to run them but if u want the max performance out of them you should hook them up to a amp.........
Old Nov 10, 2009 | 06:05 PM
beav's Avatar
umm thanks i guess...but you didnt really answer anything i was asking about, lol.
i dont want super performance, i just want the tweeters NOT to blow, if i dont use a crossover. thats what i wanted to know...can i run them safely without a crossover?
Old Nov 10, 2009 | 06:50 PM
audioroach's Avatar
No...you need some type of crossover to protect the tweeter. A simple capacitor in line would suffice. The values are in micro-farads. (use from 4 to 10 microfarad.) This will be a simple high pass 6 db filter.
10 microfarad = 4000 hz
4 microfarad = 10,000 hz
Old Nov 10, 2009 | 07:24 PM
beav's Avatar
holy crap, i didnt understand any of that.
i will ry to read up on whatever all that meant, but how come the oem tweeters dont blow if they are ran off the same mids with no crossovers?
Old Nov 10, 2009 | 09:53 PM
mrdeadman's Avatar
They let me pick
Make/model of components please.
A capacitor run in series with the voice coil of the tweeter will cut out the lower frequencies and only pass the higher frequencies.
If you are skilled in electronics (which you probably aren't otherwise you would understand the capacitor thing, no offense) you can build a better high pass filter and run that. You can wiki high pass filter for more info.
Old Nov 10, 2009 | 11:14 PM
mooze's Avatar
if you bought them new and they didnt come with an external crossover they prob already have inline caps in them.
Old Nov 11, 2009 | 02:10 AM
audioroach's Avatar
LoL...and I thought i was keeping it simple . The reason you typically don't blow the oem tweeters is because they have this type of crossover on them. It keeps the speaker from trying to play music (frequencies) that would destroy it. Depending on manufacture its either mounted on the speaker or in line in the wiring. (Take a look at the oem speaker...there may be what looks like a small round can attached to the speaker....this is the crossover)
Hope this helps
Old Nov 11, 2009 | 03:29 AM
beav's Avatar
thanks guys...lotta help.
TailZ
Audio / Security / Video
Sep 8, 2011 06:07 PM
hybrid90
Apr 11, 2011 11:23 AM
kyorishin
Feb 14, 2006 10:28 AM
92BlackSi
Apr 2, 2004 04:33 AM
BnTBoz
12
Mar 22, 2003 06:48 PM
