Advice on setup (stereo gurus)
Old Mar 20, 2003 | 10:45 AM
BnTBoz's Avatar
Default Advice on setup (stereo gurus)
I would like to hear opinions on which setup I should go with.
First of all, I have 2 small amps (35w/2 or 100w/1) and already have a new HU, an EQ, and a good size amp with a 12" sub. My question is, which would be better for the use of the 2 small amps?
1 - Get 2 pair of descent 2-3 way speakers and run 1 amp on each set.
2 - Get 1 good set of component speakers for the front and run one amp to each of those and get some average speakers for the rear (fill) and power them with the HU.
I'm not looking to win any competitions, I just want the best sound quality possible.
Bobby
Old Mar 20, 2003 | 10:55 AM
nsxxtreme's Avatar
Default Re: Advice on setup (BnTBoz)
Uhh would need to know what the two amps are. My 25wX2 is capable of putting out 1000wX1 so it depends.
Old Mar 20, 2003 | 11:23 AM
1BlackHatch's Avatar
I would say power front components with the amps and use the HU for rear fill. Personally I would buy a good 4 channel amp, but that's me. If you don't wanna spend any more money then I can understand. I just don't like having amps all over the place... I run a channel... God, I'm rambling....
Old Mar 20, 2003 | 03:01 PM
BnTBoz's Avatar
Default Re: Advice on setup (nsxxtreme)
The 2 small amps are Pioneer GM-X332's. They are descent little amps and are capable of putting out the power they claim.
I don't want to buy anything else from here on but speakers. I took everything out of my old car (except for the speakers) before I sold it. I have pretty good sound in my car right now but since I have all this stuff sitting around and I'm bored, I want to put it all in my new car but I just want to do it right the first time.
That's the reason why I have 3 amps to begin with. I started with just 1 small one and my brother gave me a big one. So I bought a sub.....anyway, what would you do?
Thanks, Bobby
Old Mar 20, 2003 | 05:22 PM
JOMO
Guest
Posts: n/a
I 2 - Get 1 good set of component speakers for the front and run one amp to each of those and get some average speakers for the rear (fill) and power them with the HU.
im no guru but... to this
Old Mar 20, 2003 | 06:19 PM
STSProtege's Avatar
Default Re: Advice on setup (JOMO)
i agree with 1blackhact, power a comp set up front with the more powerfull of the 2 small amps, rears get the second small amp, big amp with the subs.
Old Mar 21, 2003 | 07:13 PM
koco's Avatar
If your amp is 2 ohm stable, you could run front and rear speakers with it. It would sound more balanced that way. Not a great plan to run half from amp and half from HU. The only drawbacks are" the amp would run hotter and you wouldn't be able to fade from front to rear and vice versa.
Old Mar 21, 2003 | 10:16 PM
STSProtege's Avatar
Default Re: Advice on setup (koco)
balanced as in the front and rear play at the same level and same frequency cut off, no indivdual control, no front rear fading, no good for imaging and staging at all, amp runs hotter and in turn has less life, not good for a budget system........and this is a good thing?
Old Mar 22, 2003 | 09:44 AM
CRneXt's Avatar
Default Re: Advice on setup (STSProtege)
My recomendation would be to sell the 2 amps that you have already. Get something like a 5 channel Memphis Belle MC600D (55w X 4 RMS, and 400W X 1 at 1 ohm) Get yourself some great coaxes or some nicer components, and locate them in the stock locations. The 4 channels by 55 are 2 ohm stable, so if you wanted to use some Q logic Qforms, do that along with the Stock locations... Then Grab a DECENT SUB, like a Kicker CVR12 Dual 2 ohm sub. Wire the Voice coils in parallell, and voila! 400 watts, which is close to it's RMS rating. (50 watts over will not kill it, if you reduce the gain) Build that box slightly small for Harder hits, larger for the deep drawn out transients. Your choice, you will have to live with it.
I am MECP Certified
Certificate# provided upon request
Scott AKA CRneXt
Old Mar 22, 2003 | 05:02 PM
IEATLINT's Avatar
it also depends on how big your car is. for example i have a crx with a 6 1/2" component set built in to custom kickpannels all running on a 4 channel. i have completly eliminated rear speakers which in turn brought my soundstage forward which i happen to like the sound of alot more. if i left rear speakers in, they would be so close to my ears it would ruin the effect all together. but if you have a large car, you might like to have a little rear fill, and if so just power that with your h/u so its not overpowering. hope this helps.
Old Mar 22, 2003 | 05:15 PM
JOMO
Guest
Posts: n/a
Default Re: Advice on setup (IEATLINT)
so, you have no sub?
Old Mar 22, 2003 | 05:18 PM
koco's Avatar
Now how hot exactly would his amp run? Who really knows. Try it and see, I have done it successfully many times. As far as frequency cutoff, why does it need to be different? Ever heard of passive crossovers? Well they aren't expensive? Imaging has to do with speaker palcement not what amp you use. Why don't you suggest something better?
Old Mar 22, 2003 | 06:48 PM
IEATLINT's Avatar
no, i have a 10", all running on a Zapco 650
Pworld
Audio / Security / Video
Apr 29, 2005 09:14 PM
EF-Pimp
22
Nov 26, 2003 08:10 PM
slow-mo
12
Jul 9, 2003 05:24 PM
ilikemyaccord
Apr 15, 2003 10:11 PM
mr_mbuna
Jul 26, 2002 07:14 AM
