Toggle switch amp voltage?
Old Feb 22, 2006 | 06:12 PM
PearlWhiteAccord's Avatar
Default Toggle switch amp voltage?
hi, i just wanted to know what amperage and voltage should the fuel pump kill switch be?? specs?? i am guessing 12 volt dc, but i c only 20, 25 and 30 amp at radio shack, TIA
Old Feb 23, 2006 | 11:36 AM
fcm's Avatar
fcm
Old Fart
Default Re: Toggle switch amp voltage? (PearlWhiteAccord)
The main fuse for the fuel pump is probably 15A - 20A but it also powers other things, but if you install the switch on the "trigger" line from the "ECM/ECU" it is a low current neg. (-) and a 1A switch should be more then big enough. 94
socalrex88
Audio / Security / Video
Mar 2, 2008 01:50 PM
OrangeBoost
Mar 29, 2005 10:37 PM
njandrewg
Oct 2, 2004 01:58 PM
projecthybrid04
Aug 31, 2003 08:56 PM
ionic_slim
May 29, 2002 08:10 PM
