Is this the proper amperage switch for fuel kill?
Old Mar 29, 2005 | 06:12 PM
OrangeBoost's Avatar
Default Is this the proper amperage switch for fuel kill?
Im doing a fuel kill switch on my civic. I have next to no electrical knowledge. I know that for the fuel cutoff you are supposed to have a 20A switch.
The package of the one I purchased says:
20 AMP 125 VAC/CA
10 AMP 277 VAC/CA
Is this an appropriate switch? Im not sure which rating to go by?
Old Mar 29, 2005 | 10:37 PM
''s Avatar
first go here and study my diagrams...
https://honda-tech.com/zerothread?id=1194912
then to answer your question, no absolutely do NOT use those switches until you know the VDC ratings. Those switches are rated at 125Volts AC and 277Volts AC. a 20 amp and 10 amp...
using relays, the 10Amp is sufficient but the switch HAS to be a 12VDC rated. Not a VAC switch. As long as the switch displays that it can be used with 12VDC then its fine.
eazy64
Oct 17, 2010 09:09 PM
socalrex88
Audio / Security / Video
Mar 2, 2008 01:50 PM
njandrewg
Oct 2, 2004 01:58 PM
projecthybrid04
Aug 31, 2003 08:56 PM
all stock
18
Feb 14, 2003 04:56 AM
