fuel pump kill switch question
Old May 29, 2002 | 02:09 PM
ionic_slim's Avatar
Default fuel pump kill switch question
I'm planning on putting a switch and a 30amp fuse between the wires that run from the fuel pump to the front of my Civic. Will this setup work? I read in the previous post that you would have to use a relay...why???
Old May 29, 2002 | 03:50 PM
t's Avatar
t
Default Re: fuel pump kill switch question (tazmoe)
because of the amp rating on the switch is not enough. (unless you find one that is, you should use a relay)
Old May 29, 2002 | 04:31 PM
ionic_slim's Avatar
Default Re: fuel pump kill switch question (t)
What do you mean the amp rating on the switch is not enough?? I should get a 30amp fuse with a 30amp switch??
Old May 29, 2002 | 08:10 PM
Sinitro's Avatar
No need for a fuse, already fused in the factory harness..
Just insert a single pole/single throw switch on the ground side of the fuel pump..
92integraVTECgsr
Audio / Security / Video
Oct 10, 2005 09:14 PM
92integraVTECgsr
Oct 10, 2005 07:24 PM
TypeRod
Sep 7, 2003 07:20 PM
projecthybrid04
Aug 31, 2003 08:56 PM
TurboTurtleGSR
Jan 17, 2003 09:04 PM
