Kill Switch on Fuel pump question!!!!
Old Aug 25, 2003 | 03:43 PM
projecthybrid04's Avatar
Default Kill Switch on Fuel pump question!!!!
I have put a fuel pump kill switch. All i did was cut the yellow and black wire and got a 25 amp switch from radio shack and connected the fuel pump with those wires. You think that 25 amp switch will hold it. I have been using if for about 2 weeks with no problems but today my brothers switch went out on him. I just have a stock feul pump and he has an aftermakrket. What do u guys think i should do? put a relay in or what?
Old Aug 25, 2003 | 09:27 PM
WickedKP's Avatar
Default Re: Kill Switch on Fuel pump question!!!! (projecthybrid04)
it's is always recommened to use a relay even so your using a high amp switch. the relay is built to handle the ark inside much better unlike the switch.
Old Aug 25, 2003 | 09:37 PM
rjr162's Avatar
Default Re: Kill Switch on Fuel pump question!!!! (WickedKP)
yeap, plus two other things. Make sure your switch is rated 25 amps DC, not AC. Switchs can handle a higher AC voltage and amps than they can DC. Most larger relays though can handle 40+ amps @ 12 volts.
Old Aug 26, 2003 | 02:14 PM
Default Re: Kill Switch on Fuel pump question!!!! (rjr162)
thanks for the responses
Old Aug 27, 2003 | 08:20 PM
MrIllegalX's Avatar
i want to do this, but I'm afraid of cutting wires that are vidal to my car running. what's the difficult of installing a kill switch?
Old Aug 29, 2003 | 01:01 PM
Default Re: (MrIllegalX)
its very easy acutlly, use the search and find out
Old Aug 29, 2003 | 09:17 PM
snapcase318's Avatar
I have a questions about this myself: would the relay go between the pump/switch or firewall/switch? Any one have a part number for a relay that's worked for them?
Old Aug 30, 2003 | 12:28 AM
DownBoyDown's Avatar
I just wired up a 20amp toggle switch to my fuel pump power line last week. It was really simple. No problems so far but Im just afraid that the switch might burn out like it has to alot of people on this board. Does anyone know what causes the switch to burn out? Whats the longest youve had just a switch wired in without it burning out?
Old Aug 31, 2003 | 08:56 PM
doublejz's Avatar
Default Re: (DownBoyDown)
like previously mentioned, make sure its rate 20amp dc, if its ac that would be a good reason why it could burn out.
integra_101
Jul 29, 2014 07:25 AM
socalrex88
Audio / Security / Video
Mar 2, 2008 01:50 PM
TypeRod
Sep 7, 2003 07:20 PM
all stock
18
Feb 14, 2003 04:56 AM
ionic_slim
May 29, 2002 08:10 PM
