thermal light on amp?
Old Aug 12, 2007 | 03:44 PM
muhaMan's Avatar
Default thermal light on amp?
ok, i had a really weak amp trying to power my L7, it was barely hitting so my friend let me have his old amp that he used to use.. we just hooked it up and the amps not powering the sub at all and the "Thermal" light comes on.. does anyone know wtf that means? also when we were in the process of switching amps, 2 of the wires sparked, so do you think we possibly shorted out the conneciton?
Old Aug 12, 2007 | 06:05 PM
skingfreak's Avatar
Default Re: thermal light on amp? (muhaMan)
Which two wires arked?
Old Aug 12, 2007 | 08:03 PM
muhaMan's Avatar
the ground and the 12v wire
Old Aug 12, 2007 | 08:17 PM
fcm's Avatar
fcm
Old Fart
What model of the L7?
What is the make and model of the amp?
When you shorted, ["2 of the wires sparked"] the power and ground leads together, did it not blow the fuse on the power lead, by the batt.? 94
Old Aug 12, 2007 | 08:38 PM
muhaMan's Avatar
dont know the model of the L7, the amp is a Koiler, dont know the model of that either.. i checked both of the fuses and they both looked good but the flippin POWER light wont come on just the gay thermal light
Old Aug 12, 2007 | 09:26 PM
fcm's Avatar
fcm
Old Fart
Default Re: (muhaMan)
If the main power fuse is an AGU, [big glass type fuse] replace it even if it looks good.
Also, disconnect subs speaker wires from amp and see what happens.
Touching the power and ground together should not do anything to the amp. 94
Old Aug 12, 2007 | 09:33 PM
muhaMan's Avatar
cool ill try that, thanks for the help
Keangdawizes
Audio / Security / Video
Jun 4, 2008 08:09 AM
CivicSiRracer69
Oct 18, 2003 04:25 PM
lilman36
Oct 4, 2003 01:47 PM
EBP_SI
Apr 29, 2003 02:55 PM
BoroDB8
Oct 15, 2001 01:09 AM
