testing subs
Old Feb 23, 2003 | 04:39 PM
Integra187's Avatar
Default testing subs
whats the best way to make sure some subs are in good condition and not blown? thanks
Old Feb 23, 2003 | 04:44 PM
t0p_sh0tta's Avatar
Default Re: testing subs (Integra187)
Umm.... hook them up.
Old Feb 23, 2003 | 09:43 PM
TurboBumblBee's Avatar
Default Re: testing subs (t0p_sh0tta)
um yea that works, or you could get a multimeter and test for ohms and continunity as well.. hookin up will take longer than testing it the correct way..
Old Feb 23, 2003 | 10:01 PM
ratherbewalking's Avatar
Default Re: testing subs (Hybrid95CivicEX)
im waiting on someone to say take a 12volt battery to them... lol
Old Feb 24, 2003 | 06:58 AM
nOOber's Avatar
Default Re: testing subs (ratherbewalking)
^ Why not ? if they don't pop, there's no continuity throught the speaker. Also good for confiriming polarity.
[Modified by nOOber, 10:59 AM 2/24/2003]
Old Feb 24, 2003 | 11:41 AM
t0p_sh0tta's Avatar
That won't tell you if there is a mechanical problem. I've seen several woofers where the spider detached from the basket/frame.
Old Feb 24, 2003 | 08:29 PM
nsxxtreme's Avatar
A mutimeter will only tell you if a speaker is blown (sometimes). A speaker is basically an inductor with a magnetic field around it. The dc impedence is usually measured (which is the measurement stamped on the speaker). Speakers really dont function in the dc world. They fuction in the ac world. Which means the impedence changes with frequency. To complicate matters more you have a magnetic field around the inductor. When this changes it wil induce a charge in the inductor. Move the speaker when the multimeter is hooked up you will see the impedence change while the speaker is moving.
The point of all this: There is more to a speaker than the dc responce. There can be all kinds of internal problems a multimeter won't find.
Hooking them up is the best way to check them, play them at several different volumes.
mkrieger500
Audio / Security / Video
Aug 28, 2009 12:46 PM
KCUF_DB8
Sep 3, 2008 09:47 PM
nub_pwn
Sep 16, 2006 08:21 PM
nsxxtreme
16
Dec 16, 2005 08:56 AM
XtremeGirlRacer
27
Apr 8, 2003 01:34 PM
