stereo issues
Old Aug 27, 2009 | 07:55 PM
mkrieger500's Avatar
Default stereo issues
I have a Dual 4 ohm 12in Type R wired down to 2 ohms paired with the alpine mrp-m1000 amp and an alpine cda-9885 deck. I built a new box for the sub to alpine specs about one month ago. really loud and clean sounding. Over the past couple of days, I noticed that the sub was getting queiter and the speakers were also barely quieter (maybe it was just me). Now the sub sounds like a pair of 6x9s. I work at best buy back in the install bay so I had tools to test. Each voice coil on the sub showed 4 ohms, the amp was getting power, and all of my settings are correct on the deck and amp. I am starting to think that the amp is bad or quite possibly the deck. Any suggestions, comments, and help is appreciated!!! Thanks!
Old Aug 28, 2009 | 04:41 AM
jason0123's Avatar
Default Re: stereo issues
try another sub in there but I would still say it is the amp
Old Aug 28, 2009 | 06:24 AM
ken9's Avatar
Could be that song you play isn't that loud.
Old Aug 28, 2009 | 07:23 AM
zsudz922's Avatar
check your battery. same thing happen to me and my battery went to ****.
Old Aug 28, 2009 | 09:03 AM
Will try battery. Its an optima yellow top. And I tried different types of media. my aux input for my zune and cds (not burned ones). A buddy of mine is gonna help me switch stuff to his amp and deck and then try my amp and his deck and see if there is a difference. Thanks for the input.
Old Aug 28, 2009 | 10:23 AM
How did you check your battery?
Old Aug 28, 2009 | 11:10 AM
twentyhurtz's Avatar
sounds like loss of power across the board..
Old Aug 28, 2009 | 12:46 PM
Ok figured it out. I remembered to check all but one setting on the deck. The loudness setting was off. One of those "I am an idiot" times. Sorry to waste everyones time. Thanks for your input though. That setting alone made the difference I was missing. A cup in the cup holder must have held down the button long enough to turn it off. Problem solved. Thanks!
Stock90Civic
Audio / Security / Video
Mar 14, 2009 11:24 AM
tomek5x
Jul 10, 2007 04:18 PM
nub_pwn
Sep 16, 2006 08:21 PM
tequilakid
Aug 31, 2005 05:34 PM
mulletov
Aug 6, 2005 07:59 PM
