system vs. pulley
Old Jan 11, 2005 | 11:09 PM
AZNBIGPIMPN505's Avatar
Default system vs. pulley
i have a civic with a underdrive pulley an im really thinking about putting in a system. what are my chances of my batterie an my alternator going out? im putting a bazooka p miller amp an subs. 1200 watt amp
Old Jan 12, 2005 | 07:39 AM
fcm's Avatar
fcm
Old Fart
Default Re: system vs. pulley (AZNBIGPIMPN505)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by AZNBIGPIMPN505 &raquo;</TD></TR><TR><TD CLASS="quote">i have a civic with a underdrive pulley an im really thinking about putting in a system. what are my chances of my batterie an my alternator going out? im putting a bazooka p miller amp an subs. 1200 watt amp </TD></TR></TABLE> if you are going to run a 1200 watt amp, you will need to replace your alt. with a bigger one, you will also need a very good batt. and I would also install a cap or two, [ 1 0r 2 farads]
A 1200 watt amp will draw peaks of around 170 amps when cranked you will need a 2 ga power wire if its going to be longer then 8 ft that said what is the RMS power of the amp? 94
Old Jan 12, 2005 | 07:57 AM
Default Re: system vs. pulley (fcm)
im not to sure but its the sony 1200
Old Jan 12, 2005 | 12:29 PM
EBP_SI's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by AZNBIGPIMPN505 &raquo;</TD></TR><TR><TD CLASS="quote">im not to sure but its the sony 1200</TD></TR></TABLE>
lol...so you should be looking at like 200 RMS
Old Jan 12, 2005 | 06:37 PM
Default Re: system vs. pulley (EBP_SI)
hahaha thanks man
Old Jan 12, 2005 | 06:45 PM
nystateofmind27's Avatar
Find out the exact RMS rating of the amplifier then crunch some numbers. If the RMS is around 200-300 watts you should not have any problems.
To find out the approximate number of amperes a system would use at maximum volume take the RMS rating of the amp and divide it by 12.
Old Jan 13, 2005 | 12:01 PM
Odessa's Avatar
Wow, get a heavy duty 300 amp alternator or else you're screwed
LadyCivic91
Mar 13, 2013 01:01 PM
RocknRolla
Audio / Security / Video
Oct 1, 2009 06:06 AM
CrazyModGSR
May 8, 2006 04:38 PM
ode1085
Dec 16, 2003 03:07 PM
Mr. Thunderlips
Nov 1, 2001 01:27 PM
