System !POPS! when car shuts off...HELP
Old Dec 18, 2002 | 04:37 PM
watacivic's Avatar
Default System !POPS! when car shuts off...HELP
when i turn the key to turn off the car while the music is playing, my system makes a loud pop(sounds like a smote of bass)...i want to know what is making the distraction to my system and how could i make it go away?? THANKS GUYS
Old Dec 18, 2002 | 09:51 PM
rjr162's Avatar
Default Re: System !POPS! when car shuts off...HELP (watacivic)
Most likely a ground loop or just the current drawl. Check the ground on your amp, make sure it's good, and if so use an inline DC isolator on the RCA lines.
Old Dec 18, 2002 | 11:31 PM
philly-O's Avatar
Default Re: System !POPS! when car shuts off...HELP (rjr162)
are you using your factory headunit or an aftermarket?
Old Dec 19, 2002 | 05:52 AM
Desslok's Avatar
Default Re: System !POPS! when car shuts off...HELP (peichie)
rjr162 hit it, but if that still doesn't work I've seen a small cap on the turn on wire to the amp help, that way it slowly loses power instead of all of a sudden.
Old Dec 19, 2002 | 08:34 PM
watacivic's Avatar
Default Re: System !POPS! when car shuts off...HELP (sp)
i am running an aftermarket head unit...some cheap thing...would a capacitor do the job??
Old Dec 19, 2002 | 08:37 PM
watacivic's Avatar
i have an EG hatch...the ground wire is connected to the seat smote thing...amp lays right on back of the rear seats and i put the seats down
Old Dec 19, 2002 | 11:01 PM
philly-O's Avatar
make sure you have a good chasis ground, and that you are using the remote turn-on wire that comes out of the deck (blue w/ white stripe wire)
Old Dec 20, 2002 | 08:21 AM
GSRaCeRbOI's Avatar
I'm guessing its a bad ground.. are you getting a good ground (on all the components of the stereo system) on a bare metal surface? otherwise it could be your admittedly "cheap" head unit... check the grounds and other connections first...
Old Dec 20, 2002 | 12:46 PM
XDEep's Avatar
ya the last resort is to do this. i did so on my last system. i forget what the values are but you can tailor it to how many seconds you want it to stay on. if i remember correctly you need a cap and a diode.
Fit a diode in the processor's turn-on lead, striped side towards the EQ. Then add a capacitor in parallel, the (+) side of the capacitor connects to the striped (processor) side of the diode, the (-) side of the capacitor goes to ground (not the radio or EQ chassis - connect to the car chassis).
Experimenting with the cap value will give you the right amount of delay before the EQ shuts off. You don't want it too long, just long enough to make sure the amp is off before the EQ powers down. 220 - 1000 uF is about right, and make sure the capacitor is a polarized electrolytic, 16V or higher.
Old Dec 20, 2002 | 01:32 PM
CIVIX's Avatar
Do you have your remote wire connected to your radio or do you have it connected to your fuse box? My friend has his connected to his radio fuse and his subs pop when his system turns on and when he shuts his system off!!! He said he did this for headunit reasons. If the ground and the power cable ever touched he wouldn't blow out his headunit only the fuse and he showed me and I found that to be a good way to go instead of a blown headunit!!!
Old Dec 20, 2002 | 11:21 PM
watacivic's Avatar
Default Re: System !POPS! when car shuts off...HELP (CIVIX)
my remote wire is connected to my headunit...where would be a good place for a good ground wire in my hatch??
Old Dec 22, 2002 | 11:00 AM
CIVIX's Avatar
Where are you going to put your amp. Under the driver seat passenger seat, hatch???
Old Dec 22, 2002 | 10:00 PM
watacivic's Avatar
my rear seats are down and i mounted the amps right on top of the rear seats on the back...
Old Dec 23, 2002 | 12:08 AM
philly-O's Avatar
make sure that you use the floor of the car to ground the amp. scrape the paint in the area that you will use to ground and also use a star washer.goodluck
eggie75
Audio / Security / Video
Dec 13, 2011 05:31 PM
lmike6453
Aug 3, 2007 03:52 PM
eLeCtRoNSi00
Apr 8, 2006 11:24 PM
hondaracing1
Jul 23, 2004 08:13 PM
ChaosUnbound
Feb 24, 2004 04:20 PM
