System control wire.....
Old Jul 23, 2004 | 05:38 PM
hondaracing1's Avatar
Default System control wire.....
i got my 2 12's hooked up and everything but it dont play with the music and it makes a thumping noise every like 2 seconds. The blue wire im guessing is the system control wire was hooked up to a fuse...should that be ran to behind the radio?
Old Jul 23, 2004 | 08:13 PM
fcm's Avatar
fcm
Old Fart
Default Re: System control wire..... (hondaracing1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hondaracing1 &raquo;</TD></TR><TR><TD CLASS="quote">i got my 2 12's hooked up and everything but it dont play with the music and it makes a thumping noise every like 2 seconds. The blue wire im guessing is the system control wire was hooked up to a fuse...should that be ran to behind the radio?</TD></TR></TABLE> Th system control wire [amp trigger wire] needs 12v+ on it to turn on the amp, amp gets its power from the batt. and the amp has to have a ground [ a good ground with as short a ground lead as posable]
Power for amp MUST come from batt.
Ground MUST be a good one
The trigger wire can get its 12v+ from any 12v switched power. most HU have a amp control output.
I would recheck all your wiring for the amp , and a very close look at the ground [thumping noise every like 2 seconds]
hope this helps. 94
sasser43
Audio / Security / Video
Jan 4, 2007 05:13 PM
boostincoupe
Oct 6, 2005 05:19 PM
weak_tec
Jul 13, 2005 07:03 PM
Kavehman
Oct 30, 2004 05:44 PM
ChaosUnbound
Feb 24, 2004 04:20 PM
