system out of wack
ok so the other day i took my sub out and when i went to put it back in the neg. and pos. wires touched and now when i put the volume on zero u can sill here the sub vibrating. I switched my amp and sub with my friend to test it and it still does it plus i changed the fuse.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 97dc2 »</TD></TR><TR><TD CLASS="quote">ok so the other day i took my sub out and when i went to put it back in the neg. and pos. wires touched and now when i put the volume on zero u can sill here the sub vibrating. I switched my amp and sub with my friend to test it and it still does it plus i changed the fuse.</TD></TR></TABLE> Check the only thing you haven't yet , the RCAs and the HU.
94
94
this is exactly what happen to mines. the sub vibrates when the volume off.. i dont know why u switch with your friends sub and still didnt work. but i just change my amp and it works perfectly fine now
i changed the rca's last night and it worked fine but this morning when i went to school it sounded the same again. and i have my friends amp in my car now.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 97dc2 »</TD></TR><TR><TD CLASS="quote">i changed the rca's last night and it worked fine but this morning when i went to school it sounded the same again. and i have my friends amp in my car now.</TD></TR></TABLE>OK, this is what may have happend, if for any reason you lose the ground on the amp when its on, and the RCAs are hooked up, the amp will try to get it's ground through the RCAs, and as the RCA ground is for signal only. it's very thin, so what happens is the tracer on the PC board blows like a fuse, and as you have now tryed everything else, I would try another HU. sorry all I can think of
94
94
craftysince86
Audio / Security / Video
May 10, 2006 04:22 PM
