FOSGATE AMP PROBLEM
Old Dec 14, 2005 | 02:17 PM
db8geezer's Avatar
Default FOSGATE AMP PROBLEM
hey guys i got a rockford fosgate 700s amp....the fuse that is connected with the battery terminal popped and i put new ones in and they popped also when i turn on the car....i went to a car audio shop they said the amp was short circuiting or something like that...is there any other thing that can be wrong or how can i check out the amp to see if its still good ?? thanks
Old Dec 14, 2005 | 03:41 PM
matt_in_sd's Avatar
Default Re: FOSGATE AMP PROBLEM (db8geezer)
You have already proven the amp is shot.
Repair it or replace it.
Old Dec 14, 2005 | 04:11 PM
fcm's Avatar
fcm
Old Fart
Default Re: FOSGATE AMP PROBLEM (matt_in_sd)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by matt_in_sd &raquo;</TD></TR><TR><TD CLASS="quote">You have already proven the amp is shot.
Repair it or replace it.</TD></TR></TABLE>Ditto that, most likly blown outputs. 94
Old Dec 14, 2005 | 06:47 PM
nsxxtreme's Avatar
Default Re: FOSGATE AMP PROBLEM (fcm)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fcm &raquo;</TD></TR><TR><TD CLASS="quote">Ditto that, most likly blown outputs. 94</TD></TR></TABLE>
Sounds like a blown input to me As in DC input transistors.
Wanna sell it?
Old Dec 14, 2005 | 07:52 PM
db8geezer's Avatar
thanks...do u guys know where or how much it would cost to fix and if its worth fixing ? im in the los angeles area...
Old Dec 22, 2005 | 03:57 PM
matt_in_sd's Avatar
Most shops run $100 or more. I moonlight fixing amps. What Part of LA? I usually can fix then for less then $75, but it depends on how much damage is done.
Old Dec 22, 2005 | 05:42 PM
nsxxtreme's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by db8geezer &raquo;</TD></TR><TR><TD CLASS="quote">thanks...do u guys know where or how much it would cost to fix and if its worth fixing ? im in the los angeles area...</TD></TR></TABLE>
If you have some soldering skills fix it yourself. Amps are simple and parts shouldn't run more then $20 if that.
Take it apart and post some pics.
lsracer27
Audio / Security / Video
Jun 14, 2006 01:42 AM
{Powered by VIII}
27
Jan 15, 2006 09:10 AM
shyboy817
Dec 25, 2004 01:31 PM
skrewdriver88
Aug 24, 2004 08:21 PM
BuddyC
22
Apr 13, 2004 02:58 PM
