switch amp power without headunit
Old Dec 18, 2002 | 10:18 AM
4doorH22's Avatar
Default switch amp power without headunit
Hi, I've hooked up my Nomad Jukebox directly to my crossover, totally bypassing my headunit. Of course the problem is the amps and crossover only switch on with a signal from the headunit. I want to set up a switch to switch the power on manually, but that is a very low current circuit, right? What (always on) power line can I tap to switch the turn-on leads?
Thanks
Old Dec 18, 2002 | 10:39 AM
Desslok's Avatar
Default Re: switch amp power without headunit (4doorH22)
You can grab power for it at any power source including the factory wire for the HU, just put a small fuse on the wire (5 amp). I have also seen a switch for purposes like what you are doing that you tie into power and the signal to the amp, and when it senses current on the low level inputs to the amp, it will switch on and give turn on hte amp. I'll try to locate some info for you. I forget who makes it.
Old Dec 18, 2002 | 11:14 AM
4doorH22's Avatar
Default Re: switch amp power without headunit (sp)
Thanks for the reply. I guess to be ultra safe I'd put a 5A fuse by each component? That's overkill, I'll just put a single 5A fuse where the turn-on leads meet.
PS a power wire in the trunk would be easiest. Can I just tap into my Amp line as long as I put a 5A fuse near the components?
Thanks again.
Old Dec 18, 2002 | 11:47 AM
Desslok's Avatar
Thanks again.
YEs, tapping into the amp wire will work, just be sure to fuse it at he amp turn on wire. This is kind of what I was talking about here, but this one is for speaker output, you need one that will work with low level outputs, I'm having trouble finding them:
http://www.davidnavone.com/detail.asp?PRODUCT_ID=N-902
Old Dec 18, 2002 | 11:55 AM
4doorH22's Avatar
Cool. I get the idea. I'm sure a local audio store by me should have low-level auto turn on switch.
Thanks
cmilleriv
Honda Civic (2006 - 2015)
May 28, 2008 11:41 PM
RCautoworks
Audio / Security / Video
May 25, 2007 09:21 PM
RideOrDie
Dec 20, 2004 08:13 AM
Joon Joon
Dec 14, 2004 05:00 PM
Liquidgsr
Jun 30, 2003 03:58 PM
