SUB WOOFER BOXES
Old May 17, 2007 | 02:08 PM
'Accord Ex''s Avatar
Default SUB WOOFER BOXES
I just ordered a package from Crutchfield (2 12" Alpine Type E SUBS, Alpine 500 wat amp and box) I recently found out that my left sub rattles the side because it was put together poorly. I plan on ordering a new box but I dont know what ones are the best so I am asking for suggestions!
PLEASE Help
How about ENCLOSED BOXES?
Old May 17, 2007 | 02:28 PM
503_EF9's Avatar
Default Re: SUB WOOFER BOXES ('Accord Ex')
just make sure its a good quality box and youll be fine. subzero is cheap and theyre made pretty well. your subs should also come with a guide for recomended size boxes ect check that out as well. as a rule of thumb (and someone correct me if im wrong i dont claime expertise) closed boxes are tighter more acurate and less bassy people say by not to much but with my experience id say theres a world of difference between open and closed. while open boxes or ported provide heavyer bass with an increased in drag time as i like to call it (time a note is extended due to the cone still vibrating) and less accuracy. basicly if you want heavy bass for rap or its sitting in a trunk go with an open box and if its in a hatch where you hear more of the actual speaker and less of the bass closed is usualy a good choice.
also this is all from personal experience knowledge so if someone feels like correcting me on anything go right ahead i wont be hurt haha.
Old May 17, 2007 | 03:36 PM
mrdeadman's Avatar
They let me pick
Q-logic makes a decent box. Or you can make your own out of MDF.
Old May 17, 2007 | 03:43 PM
fcm's Avatar
fcm
Old Fart
Default Re: SUB WOOFER BOXES (dylan_surrender)
Your close dylan_surrender sealed boxes produce a tighter more accurate bass, vented boxes will produce a lower F3 point, [deeper bass] and will be louder then a sealed box, [same sub same amp].
The above is a generalization, you can get loud, deep bass from a sealed box, and you can get clean, accurate bass from a ported box.
You will get neither with an over the counter box, you can get pretty good bass from a sealed over the counter box.
Look for a box that is made out of MDF, [at least 3/4"] get the right volume, not hard with Alpine type E subs, for 2 subs you need 1.6-3.4 cuft, the bigger the box the deeper the bass.
I have used 3 cuft gross prebuilt boxes with these subs and it works very well.
Hint, install bracing inside the box, along all seems, [small 1"x1"x2" blocks glued along seams every 5"-8"], seal the inside of the box with a wood sealer, [I use fiberglass resin], run a bead of silicon along all seams, predrill all your mounting holes.
The box needs to be airtight for best results. 94
Old May 17, 2007 | 04:06 PM
503_EF9's Avatar
Default Re: SUB WOOFER BOXES (fcm)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fcm &raquo;</TD></TR><TR><TD CLASS="quote">
agreed. but theyve gota be close to ideal setups for the best of both worlds. if your plan on using a over the counter box i agree and would say use a sealed box if its not loud enough get a more powerful setup or an extremely nice box fcm would know alot more about those things then me. haha he uses facts i use oppinions and personal experience.
Old May 17, 2007 | 08:29 PM
wORD gUYS!
Old May 20, 2007 | 11:05 PM
nineohtoo's Avatar
Default Re: ('Accord Ex')
Fiberglass up a box :D Saved me space in my hatch and it sounds great.
cpl rampage
Audio / Security / Video
10
Jun 22, 2009 04:58 AM
v8killaz
20
Mar 18, 2008 07:56 PM
Bud
Feb 29, 2004 06:49 PM
Halo
13
Mar 25, 2003 10:09 PM
Duck Sauce
Nov 13, 2002 06:52 PM
