Sub Setup Question
Old Oct 28, 2003 | 07:15 AM
Boosted-Ek's Avatar
Default Sub Setup Question
I have 500wx2 channel amp. And three 12in 12ohm subs. What is the best way to run these. Should I just run them in series? If so, what would that make the ohm load of the sub be?
Old Oct 28, 2003 | 07:42 AM
nOOber's Avatar
Default Re: Sub Setup Question (Downs)
series would give you 36 ohms, little on the high side.
try them parallel, 3 ohms.
Old Oct 28, 2003 | 01:57 PM
showtymers619's Avatar
* B A N N E D *
Default Re: Sub Setup Question (nOOber)
turn it to 6 ohm ..
Old Oct 28, 2003 | 06:13 PM
K.Lund's Avatar
Is the amp bridgeable? If it is I would wire the subs in parallel which would be a final load of 4 ohms at the amplifier.
I Want An Si
Audio / Security / Video
10
Apr 9, 2008 02:53 PM
h22accordr
Jun 6, 2004 12:02 AM
bradykiller
Mar 31, 2004 06:48 PM
GroundZer0 336
Aug 21, 2003 09:49 AM
Adampops
Jul 30, 2002 09:52 AM
