getting new system , wiring question
Old Aug 20, 2003 | 07:41 PM
GroundZer0 336's Avatar
Default getting new system , wiring question
ok im going to get 2 15 inch rockford punch hx2 subs. (dual 4 ohm)
to power im going to get rockford 500s amps * one per sub... and it puts out 500+w rms @ 4 ohms.
so exactly how would i wire the sub and to the amp to get the most i can get out of it. would i wire it in series to keep the 4 ohm? or does series break into 1ohm.
any help would be cool. thanks
Old Aug 21, 2003 | 03:20 AM
t0p_sh0tta's Avatar
Default Re: getting new system , wiring question (lowlife4life)
If you run one amp per sub it will see a 2 ohm or 8 ohm load.
Old Aug 21, 2003 | 08:54 AM
ATF Kuk's Avatar
series will put it into 2 ohm, parallel will give u 8 ohms.
Old Aug 21, 2003 | 08:55 AM
ATF Kuk's Avatar
maybe this will help http://paudio.tripod.com/subwooferwiring.html
Old Aug 21, 2003 | 09:49 AM
Default Re: getting new system , wiring question (ATF Kuk)
so since i cant have the sub at 4 ohms and the amp having a mono load of 4 ohms, will it mess up the subs or amp if i run the sub at 2 ohms and the amp at 4? because i want to run the amp at mono 4 ohms, so i can have everything i can get out of it but i dont want to mess up the subs!
i dont really know too much about impedence so any help will be good.
thanks
civictildeath
Audio / Security / Video
Apr 8, 2009 01:57 PM
GroundZer0 336
Apr 17, 2004 08:54 AM
mstewar
Sep 10, 2003 06:54 PM
shipsaeki
Jun 1, 2003 07:19 AM
cd5_2NR
Apr 24, 2003 02:02 PM
