Sub setup help. Reliable?
Old May 9, 2013 | 01:47 AM
Sagara09's Avatar
10 Year Member
Default Sub setup help. Reliable?
I am wondering how reliable this new setup of mine will be. I had some old kenwood 12s rated at 400rms each at 4ohms each powered by a kenwood 1000 watt amp. I have ordered a new setup and all but the subs are in. I have a pioneer AVH-4300dvd that I will be replacing as well and will be up for sale soon.
Here is what the new setup consists of:
Alpine MRX-M240 amp (2400 watt at 2 ohms x 1. Monoblock)
2 Alpine type R SWR-12D2
Streetwires ZN5 amp kit
Pioneer AVH-4400BH
My question is, will this setup run reliably? Crutchfield told me that it's better to run a little over the max rms than under. Is this true or just a ploy? I have no audio experience and need some advice. Thanks.
Old May 9, 2013 | 01:53 AM
silkypillows's Avatar
Default Re: Sub setup help. Reliable?
looks good to me. crutchfield is correct. better to have more wattage than necessary. your subs will only draw as much as they can handle.
over drawing (higher rms speakers/lower rms of amp) = dead amp eventually
Old May 9, 2013 | 02:07 AM
Sagara09's Avatar
10 Year Member
Awesome. That is what I needed to know before I wire them up.
I can use a dvc 2ohm load wiring diagram and run the wires from the terminals off the box correct and not from sub to sub?
Old May 9, 2013 | 02:25 AM
i believe you are asking if you can do some of the wiring outside the box due to it's type.
if that's the case, yes. you can either run 4 wires from the two -/+ terminals on your amp, run wires from terminal to terminal on the box or use a distribution block of sorts.
Old May 9, 2013 | 04:14 AM
Sagara09's Avatar
10 Year Member
It only has one terminal.
Old May 9, 2013 | 04:29 AM
yeah a single mono -/+ terminal. technically both -/+ are each considered a terminated end i.e terminal.
or were you referring to your box? if so, just wire through it as normal. wiring the subs per the diagram.
Old May 9, 2013 | 04:36 AM
Sagara09's Avatar
10 Year Member
LOL I didnt read that right. Ill do some research on using 2 wires per terminal.
Old May 9, 2013 | 04:03 PM
edzy's Avatar
You don't have the electrical to support 1500watts
let alone 2400.
I don't even wanna know what crutchfield charged you for all of that.
Old May 9, 2013 | 04:39 PM
Sagara09's Avatar
10 Year Member
let alone 2400.
It wasn't too expensive. Total was close too 1400. It's a huge upgrade to my dd while I wait for my internals to come in the mail for my project.
How do I not have enough electrical support? The battery? I am using 0gauge wires.
Old May 9, 2013 | 04:47 PM
edzy's Avatar
how many amps is your alternator? 80?
At full tilt, that amp will be asking for close to 200 amps. You think wiring and a small battery will handle that? No.
Also, 1400 for 3 items is **** load of money.
I could've pieced together something way better for less. You should start over, tbh.
Old May 9, 2013 | 04:57 PM
Sagara09's Avatar
10 Year Member
Its in an 08 Scion Xb. Not sure of the alternator output. Not worried about it though as it puts out better sound as to what I had before.
1400 isnt a whole lot, especially when it comes to cars. Have that much in just machine work in the B16 head I have.
Old May 9, 2013 | 05:23 PM
edzy's Avatar
1400 is a whole lot when it's spent on entry level items.
For ***** and giggles,
Assuming you keep the 4400. It's 429 at sonicelectronix
That leaves $971
139
http://www.ebay.com/itm/Precision-Power-P600-2-600W-2-Channel-Phantom-Class-D-Series-Car-Amplifier-/330903828681?pt=Car_Amplifiers&hash=item4d0b67b8c9
179
http://www.ebay.com/itm/Precision-Power-P1000-1-1000W-1-Channel-Phantom-Class-D-Monoblock-Amplifier-/400458451946?pt=Car_Amplifiers&hash=item5d3d2f0bea
Sundown audio component set 199
http://store.soundsolutionsaudio.com...onent-set.html
This leaves you with 454 for sub(s)
with that, i'd pick something from the sundown sa line up
http://store.soundsolutionsaudio.com...sa-series.html
they're 100x the sub any of the alpines are...in sq and spl.
See how i was able to stretch 1400 to get u more stuff? Better stuff..
Old May 9, 2013 | 05:32 PM
Sagara09's Avatar
10 Year Member
I hear good things about Sundown. However, I dont know who the other companies are. I like to stick with what I know works. I am sure it is a nice setup though.
Old May 9, 2013 | 05:37 PM
edzy's Avatar
PPI is an old school brand.
They use to be the ****
fell off
Then came back and are taking over little by little.
calvinnguy3n
Audio / Security / Video
16
Dec 14, 2006 05:20 PM
dafuzzbudd
14
Nov 26, 2006 08:27 PM
BLKSHEEP
31
Mar 7, 2006 06:44 PM
deceit
May 13, 2002 06:12 PM
