Sub question
Old Jan 12, 2004 | 11:26 AM
CHK4TIX's Avatar
Default Sub question
ok, i have a question, this was posted in another thread but it got no responses.
Due to an car accident my two 12" fosgate Punch RFP-412 got screwed. They were being powered by a Fosgate 100ix dsm. My question is, what would be a good replacement for them. Its been a long time (obviously) since i had to buy new equipment. I am looking for single voice coil subs to go into a ported box.
Possible choices
1. Infinity Reference 1230w
2. JBL GT120
3. Kenwood KFC-w3005
4. MTX thunder 8000
And any others that you can recommend
Old Jan 12, 2004 | 12:41 PM
GAtegs's Avatar
Default Re: Sub question (CHK4TIX)
It would make it easier for someone that wants to help you if you post the specs of that amp you have.
Old Jan 12, 2004 | 02:55 PM
CHK4TIX's Avatar
Default Re: Sub question (a98tegLS)
ok, the specs that i can find are
mono into 4 ohms..................420watts
per channel into 2 ohms....................200watts
RMS continuous power mono into 4 ohms.....................200watts
This information was taken from the fosgate website. I am unable to find my original birth certificate from the amp, but i do remember that is was way underrated. Also it doenst give the info for a 2 ohm mono load which i was and will be running again.
Old Jan 12, 2004 | 03:39 PM
rcurley55's Avatar
New User
hmmm, that's odd, that amp shouldn't be run at a 2 ohm mono load...it's designed for a 4 ohm mono load....it must double as a BBQ!!
That's a sweet and very under-rated amp...I have an old 4020 and a 60 running around still.
Are you planning on a new box? What size is the box? What kind of depth do you have to work with? Budget? SQ/SPL or a mix?
Old Jan 12, 2004 | 04:01 PM
GAtegs's Avatar
I would start with buying a new amp.
Old Jan 12, 2004 | 06:05 PM
rcurley55's Avatar
New User
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by a98tegLS &raquo;</TD></TR><TR><TD CLASS="quote">I would start with buying a new amp.</TD></TR></TABLE>
That amp is sweet!! I'd never sell it...
Old Jan 12, 2004 | 06:55 PM
civicsitek GanGsTa's Avatar
Default Re: Sub question (rcurley55)
maybe check out ebay for some power 12's, or soundstream exacts or ppi flat piston. you can get any of those for around $200 for 2.
Old Jan 13, 2004 | 02:52 AM
brads94accord's Avatar
for that kind of power i recommend the infinity reference, or even the kappa 120.3SE
Old Jan 13, 2004 | 07:26 AM
CHK4TIX's Avatar
Default Re: (rcurley55)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rcurley55 &raquo;</TD></TR><TR><TD CLASS="quote">hmmm, that's odd, that amp shouldn't be run at a 2 ohm mono load...it's designed for a 4 ohm mono load....it must double as a BBQ!!
Are you planning on a new box? What size is the box? What kind of depth do you have to work with? Budget? SQ/SPL or a mix?</TD></TR></TABLE>
as far as the BBQ goes, it really doesn't get that hot the only time i have ever had it over heat what when it was over 100 deg out side and the amp had been on for a few hours.
As far as the box goes, i will be using the same box, the accident only caused damaged to the cones and a tear in the carpeting of the box, besides the back end of the car that it was in.
The box is a custom box that was build for the fosgates. It is a ported box with about 1.9 cubic feet per sub. I am looking for good SQ but wouldn't mind a mix of SQ/SPL. as far as budget goes, i wanted something fairly inexpensive say under $500. If not i think i might start a whole new system and sell everything that i have now.
Old Jan 13, 2004 | 08:43 PM
..::91TEG-G2::..'s Avatar
go for either the mtx 8000's or some alpine type R's.. they both slam like a ho on ****!!!
Old Jan 14, 2004 | 05:33 AM
CHK4TIX's Avatar
Default Re: Sub question (..::91TEG-G2::..)
thanks for the replys everyone, I think for right now im going to get mtx 8000's i was able to get a killer deal on them, so if i dont like them i know i will be able to sell them.
Old Jan 15, 2004 | 08:26 PM
lillthingz's Avatar
I would get Kicker Comp CVR's I have 2 12's and they sound gooooood.
Old Jan 16, 2004 | 07:14 AM
Default Re: (lillthingz)
how many watts can they handle?
jpangeles
Audio / Security / Video
Dec 24, 2008 06:09 PM
youknowwhoibee
14
Jun 25, 2007 03:56 PM
typeR564
Sep 21, 2005 10:35 AM
CHK4TIX
Jan 11, 2004 08:46 AM
IDriveHonda
18
Oct 9, 2003 05:43 PM
