Sub placement
Old Oct 5, 2007 | 12:07 PM
SpeedoKing's Avatar
Default Sub placement
So one of my friends came across 8, 8in 300watt pyramid subs he sold one to me for $10. i was looking of a box then i thought can i jus mount it behind my back seats like on the plastic cover behind the seat. can this be done make it looks stock and sound good? ill try and post some pics of where i want to put it. thanks for any help or pointers this is my first sub install so any help will be appreciated.
oooh yeah i have a 99 civic EX coupe
Old Oct 5, 2007 | 12:38 PM
SpeedoKing's Avatar
Default Re: Sub placement (SpeedoKing)
bump anyone...im talking about between the two speakers in the back, right behind the break light on the back window.
Old Oct 5, 2007 | 12:47 PM
bpr0422's Avatar
you could, it should be powered by an external amp... and in a sealed enclosure..
Old Oct 5, 2007 | 01:06 PM
SpeedoKing's Avatar
Default Re: Sub placement (bpr0422)
aaah ok i knew i had to have an amp but forgot about the sealed box noob mistake
Old Oct 6, 2007 | 02:29 PM
thekid03's Avatar
take a look at the specs.....I'm not familiar w/ these subs but there are subs that will do fine free-air. Make sure you mount them on a very sturdy baffle.....3/4 or 1" MDF should be fine. Maybe this is 'old-news' but thought I'd mention it anyway
I'd play around w/ placement as well.....see how they sound firing towards trunk, ceiling and front-facing...pick what sounds best to you.
Old Oct 7, 2007 | 08:45 AM
SpeedoKing's Avatar
Default Re: Sub placement (thekid03)
thanks for the advice but i did some measurements and it wont fit with out some major work so ill probably jus find a box and stick it in my trunk.
Old Oct 7, 2007 | 09:19 AM
fcm's Avatar
fcm
Old Fart
Is there a model number on the speaker, Pyramid makes/made more then a few 8""woofers", anything written on the center dust cap? 94
Old Oct 7, 2007 | 05:48 PM
SpeedoKing's Avatar
Default Re: Sub placement (fcm)
you mean the stickers on the back? it says PWF8X and under that there is a U aside for that it says 300 watts and 4 ohm.
Old Oct 7, 2007 | 06:49 PM
fcm's Avatar
fcm
Old Fart
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SpeedoKing &raquo;</TD></TR><TR><TD CLASS="quote">you mean the stickers on the back? it says PWF8X and under that there is a U aside for that it says 300 watts and 4 ohm.</TD></TR></TABLE> Yes, the Pyle PWX8X is a 150W continuous, [300W peak], MSRP is $25.00
Here are enough T/S parameters to design a box... http://www.pyramidcaraudio.com...X.pdf
Old Oct 7, 2007 | 08:42 PM
SpeedoKing's Avatar
thanks man that helped
Old Oct 8, 2007 | 10:33 PM
nauc's Avatar
i wouldnt
but i would save up and buy a quality amp and sub, put it in the right box, take out the rear dash speakers to let the bass in the trunk vent into the cabin
do it right the first time. it will save you time, money and headaches
CrockSmoke
Audio / Security / Video
Dec 4, 2013 07:24 AM
Kato7997
18
Mar 7, 2006 07:07 PM
Odessa
11
Oct 4, 2004 07:49 AM
MooreBoost
Nov 9, 2003 07:22 AM
shipsaeki
25
Jun 13, 2003 04:42 PM
