sub box material
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fcm »</TD></TR><TR><TD CLASS="quote">MDF....
94</TD></TR></TABLE>
In case you don't know what MDF is, it stands for Medium Density Fiberboard and it's the standard box-building/car audio fabrication material. You can get it at any lumber store.
Dan
94</TD></TR></TABLE>In case you don't know what MDF is, it stands for Medium Density Fiberboard and it's the standard box-building/car audio fabrication material. You can get it at any lumber store.
Dan
birch would be better than MDF. lately, i have noticed that good MDF can only be bought in specialty stores. most of the mdf i see at my local hardware store and lumber yards are pretty shitty.
make sure your box does not leak and is barely vibrating. vibrations means losing energy, losing energy means lower SPL levels. bracing is a good way to stop vibrations and 1" faces instead of the .75" norm.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fcm »</TD></TR><TR><TD CLASS="quote">Plywood for a sub box?
yes sir, it's 11 ply...
many speaker boxes are built from it, mine is
many home audio speakers/subs use it too
94</TD></TR></TABLE>yes sir, it's 11 ply...
I have been around a long time, and although I have seen sub cabinets made of plywood, even made a few myself, [marine grade Birch] I have yet to see any good quality sub cabinets made of plywood, in fact most home subs I have seen are made with particle board as are most home speaker cabinets, the higher end speaker and sub cabinets are made with MDF or solid hardwoods.
94
94
