sub box
Old 07-24-2008, 04:52 PM
dracocrx's Avatar
Default sub box
i wont to put a custom fiber glass box in my crx but i dont wont it to be to heavy any other ideas or pics dont care what size speaker
Old 07-24-2008, 05:30 PM
whereiscarmensandiego's Avatar
if u are concerned about weight just get a pair or even a single open air 10'' sub. u can mount them almost anywhere and they dont require a box. if u set it up right a pair of them would be more then enough for a crx
Old 07-24-2008, 06:41 PM
fcm
Old Fart
fcm's Avatar
Default Re: sub box (dracocrx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by whereiscarmensandiego &raquo;</TD></TR><TR><TD CLASS="quote">if u are concerned about weight just get a pair or even a single open air 10'' sub. u can mount them almost anywhere and they dont require a box. if u set it up right a pair of them would be more then enough for a crx</TD></TR></TABLE> You can't install free air subs in a hatch back and expect them to sound any good and they do need a box, just a very big one. [trunk of a car] and for them to sound any good the air space in the trunk needs to be isolated from the pass compartment as best as it can be, not really possible in a hatch back.
dracocrx You have a few options, a single 10" will fit in a very small cabinet, [depending on sub], a spare tire well fiberglass cabinet will take up very little room and not add a lot of weight, can even be made to sit over/into the spare tire, A 10" 200W Bazooka tube, biggest one they have at the moment weighs 25lb, takes up little room and is easily movable, and sound pretty good.
http://www.bassforms.com/ may have something that you can make fit, same with...http://www.mtx.com/caraudio/products...ndexTRound.cfm 94
Old 07-24-2008, 11:38 PM
mattison187's Avatar
Default Re: sub box (fcm)
i wish i had pics of the enclosure in my rex. 2 12s fiberglassed in the spare tire well. something like that wouldnt weigh you down to bad if you go with a lighter sub. ie. audioque sd 2 or 2.5s, Re audio re series, ect. the max depth my box sticks out of the spare tire well is mabey 4"...
Edit* also you could run a setup like that with stock electrical w/o a problem.(only around 500wrms for both 12s)
Old 07-25-2008, 05:14 PM
dracocrx's Avatar
thank you for all your help im going to put a 10 or a 12 in the spar tire
BB6-213
Audio / Security / Video
10-31-2007 10:31 PM
Orpheus1985
08-18-2005 06:35 PM
FK00GSR
05-18-2005 08:01 AM
Black00Civic
09-30-2004 03:41 PM
93civdx
04-29-2003 04:32 PM
Quick Reply: sub box
