StRoBe Lights!
Old May 29, 2007 | 05:34 PM
  #26
jjmajed's Avatar
Default Re: (B18C_EJ8)
DELETE
Old May 29, 2007 | 05:38 PM
  #27
jjmajed's Avatar
Default Re: (jjmajed)
DELETE
Old May 29, 2007 | 05:42 PM
  #28
B18C_EJ8's Avatar
Wow.
Crimp Caps on alarm installs =
If you grounded it to a good chassis ground and it still does it, then it's power is getting in somewhere...
Sounds like you're going to need a relay...
Old May 29, 2007 | 05:45 PM
  #29
jjmajed's Avatar
DELETE
Old May 29, 2007 | 06:26 PM
  #30
JSPECSIR's Avatar
does the 10.2 x not have a horn honk output also? if so you can use that to drive a relay to only trigger the strobes during full alarm trigger. not during chirping.
Old May 30, 2007 | 08:28 AM
  #31
jjmajed's Avatar
Default Re: (JSPECSIR)
DELETE
Old May 30, 2007 | 03:43 PM
  #32
JSPECSIR's Avatar
should be brown. it can be programmed for pulsed or constant with valet switch or bit writer.
Old May 31, 2007 | 11:25 AM
  #33
jjmajed's Avatar
DELETE
Old May 31, 2007 | 04:18 PM
  #34
JSPECSIR's Avatar
horn output to 85, 12v constant to 86, 12v constant to 87, siren input to 30. 85 and 86 can be swapped, as can 30 and 87. the desired effect will be reached either way.
Old May 31, 2007 | 08:38 PM
  #35
bpr0422's Avatar
Coil In: Siren Out
Coil Out: Ground
Common: Backup +12V
Switched: Sirens, strobes, etc...
Old Jun 1, 2007 | 04:42 PM
  #36
JSPECSIR's Avatar
Default Re: (bpr0422)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bpr0422 &raquo;</TD></TR><TR><TD CLASS="quote">Coil In: Siren Out
Coil Out: Ground
Common: Backup +12V
</TD></TR></TABLE> thanks that helps none..... hes hooking the stobes to the horn honk output which is a neg. trigger.
alterkill1
Dec 15, 2017 03:27 AM
dale m.
Audio / Security / Video
Jan 14, 2010 07:46 PM
superthug
Oct 27, 2003 05:28 PM
Jer'rome
May 7, 2003 10:37 AM
pdiggitydogg
Mar 15, 2003 12:37 PM
