StRoBe Lights!
Old Apr 3, 2007 | 07:54 PM
jjmajed's Avatar
Default L
DELETE
Old Apr 3, 2007 | 08:09 PM
Depeche's Avatar
Default Re: StRoBe Lights! (jjmajed)
Did you think about mounting one right above the break light?
Old Apr 4, 2007 | 01:03 PM
jjmajed's Avatar
Default Re: StRoBe Lights! (Depeche)
DELETE
Old Apr 4, 2007 | 01:25 PM
94_DC4's Avatar
How about under the dash so it will flash in the eyes of the POS thief that is trying to find your alarm.
Old Apr 4, 2007 | 05:54 PM
jjmajed's Avatar
Default Re: StRoBe Lights! (94_DC4)
DELETE
Old Apr 4, 2007 | 07:10 PM
94_DC4's Avatar
Or you can wire it to the parking light output.
Old Apr 4, 2007 | 09:48 PM
12voltz's Avatar
best way to wire it up would be using the siren wire because that is a constant power source while your alarm is triggered, if you wired it up using the parklights it will flash with the parklights. Is there a reason why you do not want to use the siren to trigger your strobe lights? if you use a relay it will not lower the volume of your siren.
I think the idea of underneath your dash is a very good idea reason being the strobe will confuse and disorient any thief looking underneath your dash for the alarm brain. Maybe the engine bay too, and somewhere outside the vehicle to attract people in the surroundings.
Old Apr 4, 2007 | 09:51 PM
94_DC4's Avatar
Default Re: (12voltz)
I agree with 12voltz. It would be best to wire a relay and use the siren output. But if you decide to put it under the dash I would use the parking light output. The flashing will annoy the hell out of the asswipe trying to take your car.
Old Apr 5, 2007 | 11:06 AM
GOTSUBZ's Avatar
Default Re: (94_DC4)
sounds like a great idea
Old Apr 5, 2007 | 04:07 PM
jjmajed's Avatar
DELETE
Old Apr 6, 2007 | 05:30 PM
jjmajed's Avatar
Default Re: (jjmajed)
ttt
Old Apr 9, 2007 | 01:27 PM
jjmajed's Avatar
DELETE
Old Apr 9, 2007 | 02:59 PM
B18C_EJ8's Avatar
To hook them up to the siren output, you would need a relay triggered by the siren wire.
You do not need a relay for each strobe if your power source the relay switches to is the battery directly.
With a relay, the strobes and the siren will be sufficiently powered.
Old Apr 9, 2007 | 03:13 PM
jjmajed's Avatar
Default Re: (B18C_EJ8)
DELETE
Old Apr 9, 2007 | 11:34 PM
suspendedHatch's Avatar
Keep us updated on how it turns out. Pics if possible, or at least a good description of how it comes out. I'm wondering how easy it is to defeat. I'm also wondering if it's best to put it under the dash or maybe somewhere like the rear cargo area where it would draw attention.
Old Apr 10, 2007 | 05:55 AM
perseverance's Avatar
i'm sure it'll be easy to defeat if he wires his relay directly to the battery... all you'll have to do is pop the hood and remove the wire. does he have a backup battery? if not... then he's hooking up strobe lights for no reason.
Old Apr 10, 2007 | 12:29 PM
jjmajed's Avatar
Default Re: (suspendedHatch)
DELETE
Old Apr 10, 2007 | 04:17 PM
get a backup battery... it's one of the better prevention methods.
Old Apr 10, 2007 | 04:47 PM
jjmajed's Avatar
Default Re: (perseverance)
DELETE
Old Apr 11, 2007 | 06:37 PM
yes, it will work... it comes with a wiring diagram that's very understandable. they go for about 70bucks at my circuit city.
Old May 29, 2007 | 11:22 AM
B18C_EJ8's Avatar
Probably...
Old May 29, 2007 | 02:15 PM
jjmajed's Avatar
DELETE
Old May 29, 2007 | 02:59 PM
B18C_EJ8's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jjmajed &raquo;</TD></TR><TR><TD CLASS="quote"> So basically its constantly flickering very dim. I cant figure out why. Any ideas?
Because when the alarm chirps, it's only supplying power for a millisecond, which isn't enough time for the strobe to "charge"...
Old May 29, 2007 | 05:17 PM
jjmajed's Avatar
DELETE
Old May 29, 2007 | 05:18 PM
B18C_EJ8's Avatar
It sounds like there's 12v backfeeding in somewhere... Where did you ground the strobe?
