Stereo install help- question
Old Jul 7, 2006 | 09:16 PM
chakup's Avatar
Default Stereo install help- question
Let's see if I can describe this best-
Front speaker wires coming out of the deck- rather than wire them into the harness for the factory wiring can I just hook the wire off the deck direct to speaker wire that is ran to the respective speaker? All I'm bypassing to my knowledge is the factory wires and plug- this shoud cause no problems, correct?
Old Jul 7, 2006 | 09:28 PM
94_DC4's Avatar
Default Re: Stereo install help- question (chakup)
yes you can do that.
Old Jul 8, 2006 | 06:13 AM
fcm's Avatar
fcm
Old Fart
Default Re: Stereo install help- question (SiRGDC)
But why? 94
Old Jul 8, 2006 | 07:34 AM
chakup's Avatar
why= Need to run new wires to the crossover and new wires off of that. Might as well do it right the first time- unless I'm missing something. I am new to stereo stuff.
Old Jul 8, 2006 | 09:51 AM
suspendedHatch's Avatar
You don't have to run new wires. Use the OEM wires from the mid for the input on the crossover, then run wires to your mid and tweeter.
I pulled out the factory wiring and ran upgraded wiring, but that's just me.
Old Jul 8, 2006 | 10:00 AM
chakup's Avatar
Default Re: Stereo install help- question (suspendedHatch)
Ok yeah well I know I don't have to persay, but why not!! I figure I'll be pulling and running wires anyways might as well throw some new ones in
Old Jul 8, 2006 | 10:14 AM
Znypar's Avatar
but you could run new wires, and feel so pleased with yourself when you finish the 8-10 hour job :D. like me! lol
Old Jul 8, 2006 | 05:06 PM
fcm's Avatar
fcm
Old Fart
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by chakup &raquo;</TD></TR><TR><TD CLASS="quote">why= Need to run new wires to the crossover and new wires off of that. Might as well do it right the first time- unless I'm missing something. I am new to stereo stuff.</TD></TR></TABLE> Your running a set of component speakers off HU power?
Anyway, if that's the case, you do not need to upgrade the speaker wire if all your using is HU power, and no, it can't hurt to do so, [if done properly] but as has been mentioned, it is a bit of work to do it right, and on some Honda/Acuras it can be a real PITA, and not easy at all. 94
Old Jul 8, 2006 | 07:22 PM
chakup's Avatar
Default Re: Stereo install help- question (fcm)
Yes components off of HU for now. Just got finished. I must need an amp bad though. I have to turn it up to 25-30 to have a decent sound now. Kind of bummed. Deck is a pioneer deh-p680mp and polk mmc6500's. they sound good, just not strong right now and it almost sounds like the tweets have lot's of "air" noise, could have been the song tough.
Old Jul 8, 2006 | 08:17 PM
It's not an 8-10 hour job, even if you get frustrated and pull the entire doors, which I have done.
I'm running components off of HU power (no rear speakers) and it sounds great. It's a high output Alpine deck putting out just a little more than the recommended minimum for the components. I'm not using the passive crossovers but the active crossover in the deck. The deck actually has a switch on it for my setup.
Old Jul 8, 2006 | 08:45 PM
chakup's Avatar
Well I guess unfortunately my deck isn't very high output! Oh well, just an excuse to start shopping for more stuff I guess.
Old Jul 10, 2006 | 07:37 AM
fcm's Avatar
fcm
Old Fart
Another good reason not to run wires now, as you will have to later, if you add an amp. 94
iheartamy
Dec 23, 2006 08:43 AM
jordan-boxer
Audio / Security / Video
12
Nov 21, 2005 09:18 AM
highmilehatch
Jul 24, 2003 02:09 PM
