Rerouted hood release cable....
Old Jun 24, 2006 | 02:32 PM
bpr0422's Avatar
Default Rerouted hood release cable....
I rerouted the hood release cable through the hole where my turnsignals go...
However, the only way i got it to go through the hole was to push away the rubber...
and now there is an uncovered hole where the cable was rerouted through...
is this a bad thing??
if not.. i'm also thinking of routing my 2ga amp power line through the same hole...
if its a bad thing to have a hole through there..
what should i plug it with?
Old Jun 24, 2006 | 06:12 PM
wrx-killer-Sti-eater's Avatar
From: 99 probs but a stolen car aint 1, ca, cerritos/fullerton
Default Re: Rerouted hood release cable.... (bpr0422)
What kind of car is this? If you are going to run power wire thru it make sure the wire that is going thru the metal wall has a groument and is fused withen 6-10 inches from the battery.
Old Jun 24, 2006 | 07:38 PM
B18C_EJ8's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote &raquo;</TD></TR><TR><TD CLASS="quote">I rerouted the hood release cable through the hole where my turnsignals go...
and now there is an uncovered hole where the cable was rerouted through...</TD></TR></TABLE>
I cannot fathom why you needed to remove the rubber grommet from a 3/4 inch hole to fit a 1/8 inch cable through...
But to answer your question, no, you cannot run a power wire through an ungrommeted hole. Well, you can for a while, but it's only a matter of time before the metal works its way through and shorts that wire out.
Old Jun 27, 2006 | 04:52 PM
Skapeoner's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bpr0422 &raquo;</TD></TR><TR><TD CLASS="quote">I rerouted the hood release cable through the hole where my turnsignals go...</TD></TR></TABLE>
and it works? do you have pics of this? I am intrested.
Old Jun 29, 2006 | 09:57 AM
Skapeoner's Avatar
bump.
Old Jun 30, 2006 | 06:06 PM
fourcsan's Avatar
* B A N N E D *
i run the hood release cable thru the engine bay or in the apron upper shroud on all my cars. free security jackers cant reach under your fender and pop your hood that way. everyone do it!!!
Old Jul 1, 2006 | 08:02 PM
PnoyJeff's Avatar
Default Re: (B18C_EJ8)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B18C_EJ8 &raquo;</TD></TR><TR><TD CLASS="quote">
But to answer your question, no, you cannot run a power wire through an ungrommeted hole. Well, you can for a while, but it's only a matter of time before the metal works its way through and shorts that wire out. </TD></TR></TABLE>
hmmm....now i remember what i forgot to do...........i have a power wire running through ungrommeted holes...........thanks for reminding me...
Old Jul 2, 2006 | 09:37 AM
Skapeoner's Avatar
Is their a DIY on this somewhere with pictures?
Old Jul 3, 2006 | 06:00 AM
bpr0422's Avatar
Default Re: Rerouted hood release cable.... (Skapeoner)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Skapeoner &raquo;</TD></TR><TR><TD CLASS="quote">and it works? do you have pics of this? I am intrested.</TD></TR></TABLE>
it works after u re route it..
getting the cable out is a bitch if: you are too lazy to jack the car up to remove the tire, then remove the liner, then remove the cable... cause all you have is the spare tire jack...
http://i48.photobucket.com/alb...9.jpg
Where the hood release cable (solid black cable) passes through, is the "hole" that i'm talking about...
http://i48.photobucket.com/alb...0.jpg
This hole.. is what happens when somebody pulls away ur liner to access the hood release cable... the liner doesn't stay in.. and then gets pulled behind ur front wheel.. thus making it basically rip off...
http://i48.photobucket.com/alb...1.jpg
95 civic dx (eh2) - bone stock
http://i48.photobucket.com/alb...8.jpg
Old Jul 4, 2006 | 01:03 PM
Skapeoner's Avatar
Nice. I found other write ups on this but do you have any pics of the release coming out of the turn singles like you were talking about? For the phantom grey!! I have the same color!!
Old Jul 4, 2006 | 02:12 PM
B18C_EJ8's Avatar
I'm still having difficulty understanding why that cable wasn't run through a slit in the grommet...
Old Jul 6, 2006 | 10:04 AM
bpr0422's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Skapeoner &raquo;</TD></TR><TR><TD CLASS="quote">Nice. I found other write ups on this but do you have any pics of the release coming out of the turn singles like you were talking about? For the phantom grey!! I have the same color!! </TD></TR></TABLE>
that grommet where the wire is going through.. is the turnsignal gromment....
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B18C_EJ8 &raquo;</TD></TR><TR><TD CLASS="quote">I'm still having difficulty understanding why that cable wasn't run through a slit in the grommet...</TD></TR></TABLE>
problem is... when i poped my hood open.. my grommet was already pushed in...
by some stupid alarm installers.. who installed a crappy alarm...
i guess i could just fix the grommet, and cut a slit to route the wire through... and put some eletrical tape around it...
Old Jul 6, 2006 | 07:41 PM
suspendedHatch's Avatar
The sleeving around the hood release cable is very strong. You can't cut it with an electric saw. No worries with the the firewall.
If your OEM wire is no longer protected by the OEM grommet, that's cause for concern.
Old Jul 6, 2006 | 10:12 PM
Skapeoner's Avatar
Default Re: Rerouted hood release cable.... (suspendedHatch)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bpr0422 &raquo;</TD></TR><TR><TD CLASS="quote">that grommet where the wire is going through.. is the turnsignal gromment....</TD></TR></TABLE>
ahh... gotcha! For some reason I thought you ment that you rerouted the cable so that the hood release was next to the steeringwheel. my bad.
Old Jul 9, 2006 | 11:10 AM
bpr0422's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by suspendedHatch &raquo;</TD></TR><TR><TD CLASS="quote">The sleeving around the hood release cable is very strong. You can't cut it with an electric saw. No worries with the the firewall.
If your OEM wire is no longer protected by the OEM grommet, that's cause for concern.</TD></TR></TABLE>
Now what about running a 2ga power wire through the same hole?
I could cut a slit through the grommet and run the wire through that hole...
If thats not possible.... where would i install a new grommet?
Old Jul 9, 2006 | 02:49 PM
B18C_EJ8's Avatar
You could, but you'll probably have a bitch of a time getting it into the car that way...
Just run the power wire through the firewall like the rest of the world....
Old Jul 10, 2006 | 07:29 AM
bpr0422's Avatar
yeah.. but i have no idea where to drill a hole through the firewall to do such a thing...
have i said i'm a newb to wiring?
Old Jul 10, 2006 | 07:41 AM
fcm's Avatar
fcm
Old Fart
Default Re: (bpr0422)
Check the pass. side firewall for unused holes, a hole can be cut in the dummy plug covering the hole, if there is no unused hole there is lots of room on the pass. side to drill a hole. 94
brewerkz
Honda CR-V & Element
Feb 18, 2017 09:54 AM
cbags05
12
Aug 30, 2014 05:36 PM
mortificationrock
Nov 20, 2008 08:56 PM
brcivic411
Mar 4, 2006 02:51 PM
chrisb
Dec 11, 2005 06:20 AM
