static coming from tweeters? ipod maybe?
Old Mar 17, 2007 | 09:44 AM
MilanoCivic97's Avatar
Default static coming from tweeters? ipod maybe?
i just installed a new pair of components and there is a slight static coming from the tweeters. could this be the fact that i usa an ipod as my primary source of music? it is hardwired to the headunit...
my setup is:
CDT Audio EF-61FG with TW-25 Tweeters.
Alpine CDA-7892 HU with Media Exander set to "Mp3 Mode" (seems to have the least static.
Alpine MRP-F250 Amp bridged to 2ch with gain at 0 running the components.
8g stinger power wire routed away from stinger interconnect going to the amp.
big 3 upgrade with 0/1g power wire.
peripheral electronics ipod cord.
Old Mar 17, 2007 | 12:19 PM
B18C_EJ8's Avatar
Is the static present when you listen to the radio or a cd?
Old Mar 17, 2007 | 08:02 PM
Default Re: (B18C_EJ8)
i guess it would be a good idea to try that...lol
its really annoying. really shows up listening to rock/metal in the real high frequencies. too late to try a cd tonight the neightbor will kill me. ill let you know in the morning though.
Old Mar 18, 2007 | 05:23 PM
Default Re: (MilanoCivic97)
*UPDATE*
i tried various cd's and the static shows its *** worse. at least the problem is fixable whether it be new tweeters (hope not, mine are BRAND NEW), my wiring, or something else.
to be more specific on my current setup the 6.5's are mounted in a 3/4" mdf ring that is mounted to a sound deadened door with an airtight seal around it and the big holes covered with sound deadening. my headunit is an alpine cda-7892 with the internal amp bypassed. the gain on my bridged mrp-f250 amp is currently at zero but it gets plenty loud. with this setup i highly doubt im overdriving anything at all. the high pass filter in the headunit is set at 80hz and the one on the amp is off. 16g monster standard wire goes from the amp to the crossovers to the speakers. the tweeter wire had to be extended to be mounted in the factory locarion behind the sideview mirror, this is where my problem might be. the connection is somewhat ghetto because i lost my soldering iron and had no more crimp connectors. they are twisted and electrical taped...thats a no no i know.
Old Mar 20, 2007 | 07:41 AM
anyone?
Old Mar 20, 2007 | 10:14 PM
AP1Shocker's Avatar
Can the gain on the amp go negative? See if that works. If not, then buy some crimp connectors for your tweeters. If that doesn't work, turn your god damn stereo down you jackass.
Old Mar 21, 2007 | 12:06 PM
Default Re: (DC4Shocker)
connections are soldered...still sounds like ****.
Old Mar 22, 2007 | 09:47 PM
ARMED's Avatar
check all your connections for loose wires...
have your audio cables seperate from the power cables...
let us know whats up...
Old Mar 26, 2007 | 06:24 PM
Default Re: (ARMED)
signal cables are on the opposite side of the car from power cables.
all connections are good.
Old Mar 26, 2007 | 09:12 PM
01d17's Avatar
did you get a true component set or did you buy a set of 6.5s and some tweeters? if so you need to have a full component set that includes a crossover.
Old Mar 26, 2007 | 09:37 PM
Default Re: (01d17)
yes it's a full component set with crossover.
the crossover is currently set at "+0 db"
90_civic_Si
Audio / Security / Video
Jan 27, 2010 08:39 AM
Maleek
Jul 23, 2009 05:19 AM
92-LS-Civic
Oct 7, 2005 09:06 AM
only1crx
May 19, 2004 06:56 PM
jerm001
Apr 18, 2004 08:48 PM
