speakers?
Old Feb 22, 2011 | 08:01 AM
xpoint's Avatar
Default speakers?
Hey guys, I have a '95 prelude, and the speakers in the back don't work... I was wondering if it could be a fuse, or that they're blown? But even if they were popped, they would make a static noise... right?
I was wondering, if I could get some help, or if the wiring is off... I don't know much about speakers / stereos. Thanks for the help.
Old Feb 22, 2011 | 07:12 PM
fcm's Avatar
fcm
Old Fart
Default Re: speakers?
There is no fuse, [or should not be] on speaker leads.
The easiest test is to find a speaker that works, [any speaker] unplug the speaker leads from a rear speaker, plug them into the working speaker, if it works the speaker is the problem, [blown] a speaker with an open VC will not make any sound at all. if it does not work the problem is the wiring or the amp driving the rear speakers.
If it is a stock system, [you did not specify] the problem may be in the HU, [head unit/ radio].
You can also use a batt., [9V works best] to test a speaker, [it is a very basic test], touch the terminals of the batt. to the speaker terminals, the speaker should "pop" if not, the VC is open, if it pops it will make noise of some kind. 94
Old Feb 22, 2011 | 09:21 PM
xpoint's Avatar
Yea, it's a stock system, no amp, or anything. Will try this tomorrow, just got off of work. Thanks a lot man, I'll post on here what happens. Thanks a ton.
"the VC is open, if it pops it will make noise of some kind."
What do you mean by "vc" ?? (sorry, I really don't know anything about speakers.)
Old Feb 23, 2011 | 06:09 AM
fcm's Avatar
fcm
Old Fart
VC= voice coil, it is the speakers "motor"... http://www.bcae1.com/speaker.htm 94
Old Feb 25, 2011 | 01:51 PM
xpoint's Avatar
I connected the new speakers, and now I was able to listen to music.... Then the stereo said "protect". How do I get past that?
Old Feb 25, 2011 | 04:31 PM
fcm's Avatar
fcm
Old Fart
Can you still hear music from the speakers?
If not, check your connections, you may have a short. 94
Old Feb 25, 2011 | 07:50 PM
xpoint's Avatar
I forgot to seal up the wires, and they were just touching metal.... Making them shut off... >.> Fixed it up... Thanks a lot man!
Old Mar 1, 2011 | 12:20 AM
leotrader28's Avatar
To check speakers are working or not unplug the speaker leads from a rear speaker, plug them into the working speaker, if it works the speaker is OK
rjl2000
Apr 21, 2011 01:50 PM
cmilleriv
Honda Civic (2006 - 2015)
May 28, 2009 01:57 PM
tpot90
Audio / Security / Video
Jan 30, 2009 11:35 AM
ekillah
19
Nov 20, 2007 06:42 PM
gaydm.accord
Sep 23, 2003 10:33 PM
