Speaker Size/Keyless Entry
Old Jul 25, 2006 | 09:17 AM
Syndacate's Avatar
Default Speaker Size/Keyless Entry
Yeah I dun wanna make two seperate topics...I posted this in the tech forum for the 92-00 civic/del sol forum...I didn't realize there was a security forum in honda-tech, so here's the thread, I need some help with keyless entry/alarm:
THREAD
I have a '95 EJ1 (Civic Coupe EX)
I did know that there was an audio forum here so I'ma ask my speaker question here...on most cars, uc an put a circle speaker in the front, and an oval in the back...in my old probe I had 6 1/2's or 5 1/4's in the front and 5x7's in the rear...I'm shopping for a new speaker system for my civic since the one I was going to pull on the probe is a. useless b/c of the rear speaker size, and b. somebody basically stole the head unit..and it really seems with honda-civics..from waht I searched, that the front actually takes a larger speaker than the rear, this is what I found:
Front: 5 1/4's or 6 1/2's
Rear: 5 1/4's
Is this right? Circuit city has a nice deal on all spakers where u buy 2 of the same set u get 50% off of the 2nd set...so if I buy 5 1/4 speakers (all 4 the same), they should fit in both the front, and the back, right? They come with with conversion harnesses for the speakers, which leads me to part 2 of the question...are the connectors in the front the same as the connectors in the back? Like if I took the panels off and took off the front speaker (OEM), would it click right into the connector in the ones in the rear? Basically, are they all the same plug? Because I was searching on crutchfield and circuity city's website and it seems they have the whole "fit" or "not fit" ur car deal and if they have something like a pair that fits the front doors...will it also fit in the rear deck? (with the same speaker harness 'n all)
So if I pull the front speaker, will it plug into the rear port (all OEM), or would I have to sodder it?
The thing that's confusing is that all the sites say that my car takes 5 1/4's or 6 1/2's in the front, and 5 1/4's in the back....but when u look at the spakers in the rear, they don't look circular at all, they look very much oval...or is that just the cover? Are the stock OEM's 5 1/4's? Or are they oval?
Can somebody help me out on this, I'm trying to figure out these honda speakers...
Old Jul 25, 2006 | 10:13 AM
fcm's Avatar
fcm
Old Fart
Default Re: Speaker Size/Keyless Entry (Syndacate)
Both front and rear speakers should be standard 6.5", [not to be confused with the new over-sized 6.5"] although 5.25" can be installed in the front without any problem, but a 6.5" is needed for the rear deck.
The front and rear speaker terminals are the same, however they will not fit the aftermarket speaker, but just like the HU harness adapter, a speaker harness adapter is available. 94
Old Jul 25, 2006 | 02:34 PM
Syndacate's Avatar
Default Re: Speaker Size/Keyless Entry (fcm)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fcm &raquo;</TD></TR><TR><TD CLASS="quote"> Both front and rear speakers should be standard 6.5", [not to be confused with the new over-sized 6.5"] although 5.25" can be installed in the front without any problem, but a 6.5" is needed for the rear deck.
Ya, I know I have to sodder them or buy the harness (think the harnesses come free with the ones from crutchfeld)...but ur sure they're 6.5 all around? I have a '95 EX Coupe -- both circuity city & crutchfeld read that they take 5.25" and the front could take either that or a 6.5, but that the rear couldn't take a 6.5 :-\
and what the hell does "oversized" 6.5 mean?
Old Jul 25, 2006 | 03:04 PM
fcm's Avatar
fcm
Old Fart
http://www.lowrider.com/inform...h.php the best way to be sure is just pull one of the rear speakers.
A standard 6.5" speaker, [like your car uses] is round and uses 3 screws to mount it in a 5" mounting hole, the new over-sized 6.5" speakers will have mounting holes larger then 5" and normally use a 4 screw mounting system, and are diff. from make to make, unlike the standard 6.5", where all the makes have at least the 3 screw mount system, [most have 6 screw holes] and all use a 5" mounting hole. 94
Old Jul 25, 2006 | 07:19 PM
Syndacate's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fcm &raquo;</TD></TR><TR><TD CLASS="quote">http://www.lowrider.com/inform...h.php the best way to be sure is just pull one of the rear speakers.
A standard 6.5" speaker, [like your car uses] is round and uses 3 screws to mount it in a 5" mounting hole, the new over-sized 6.5" speakers will have mounting holes larger then 5" and normally use a 4 screw mounting system, and are diff. from make to make, unlike the standard 6.5", where all the makes have at least the 3 screw mount system, [most have 6 screw holes] and all use a 5" mounting hole. 94</TD></TR></TABLE>
Well according to that they both take 6.5's
This is ******* annoying, can somebody just tell me what the hell it takes? Every single source tells me something different, circuit city says only 5.25's max, iono what crutchfeld said, and now this is saying 6.5's
Isn't this an audio forum? Don't people know about speaker sizes in civics? Isn't that what half of this entire forum is about??
Damn this is annoying
Okay, so I can use 6.5's...on a standard screw set....circuit city's website claims I can only use 5 and a quarters in the back..
I'ma pull the speakers on my car tomorrow or the next day and measure them.. But cansomebody just tell me on an EJ1 (92-95 EX Coupe), what speaker sizes will fit...?? This is really aggrivating...circuity city has the big "X" saying certain ones won't fit, even 6 1/2's.......I just don't understand this...can somebody plz help me out majorly on this...
Old Jul 25, 2006 | 08:09 PM
wrx-killer-Sti-eater's Avatar
From: 99 probs but a stolen car aint 1, ca, cerritos/fullerton
f.c.m. told you twice what will fit. I don't know what you want to hear. You can put 5.25 in the front or 6.5 in the front. What ever you want that are between thoses two sizes. 6.5 will fit in the back.
Old Jul 25, 2006 | 08:20 PM
Syndacate's Avatar
Default Re: Speaker Size/Keyless Entry (wrx-killer-Sti eater)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by wrx-killer-Sti eater &raquo;</TD></TR><TR><TD CLASS="quote">f.c.m. told you twice what will fit. I don't know what you want to hear. You can put 5.25 in the front or 6.5 in the front. What ever you want that are between thoses two sizes. 6.5 will fit in the back.</TD></TR></TABLE>
Yo, I understand that for the front, 5 and a quater or 6 and half's will fit....but why on all the speaker store sites do they tell me that only 5 and a quarters'll fit in the back...it doesn't make sense as usually rear speakers are the same sizes are larger..but definately not smaller...but like circuit city and such claim that I need 5 and a quater's...want a screen shot? Just go to HERE, select 1995, Honda, Civic, 2 dr coupe (it's an EJ1 (EX)), and click "change speaker location" and u'll see what I mean, if not I"ll post a screen shot :-\
It's got all the 6&1/2's and 5&1/4's for the front, but only 5&1/4's for the rears....see what I'm sayin?
Old Jul 26, 2006 | 02:55 AM
They use 2 diffrent systems to determine what will fit. You will be fine. I am doing a complete system this week in your car. I'll post pictures of me putting 6.5 in the back if it will help you and to make you feel better.
Old Jul 26, 2006 | 03:19 PM
fcm's Avatar
fcm
Old Fart
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Syndacate &raquo;</TD></TR><TR><TD CLASS="quote">
It's got all the 6&1/2's and 5&1/4's for the front, but only 5&1/4's for the rears....see what I'm sayin?</TD></TR></TABLE>I don't know what better advice I can give then "pull a speaker and be sure" It would not surprise me one bit if your car had 5 1/4" speakers in the rear, all the 95 Civic coupes I have done, [Canadian] have a standard 6.5" speaker in the front and rear, it could well be that the first 95 Civic coups that came out had 5.25" speakers in the rear, but someone decided that they sound like ****, and changed to a 6.5" after a lot of "what fit sites" had already put 5.25" on their sites, what is the build date of your car?
So before you have an aneurysm pull a rear speaker and you will know for sure. 94
Old Jul 26, 2006 | 09:27 PM
Syndacate's Avatar
Ya, word up man, I'm sorry if I sound(ed) like a ****** *******, workload's been so ******* hard that I seriously haven't even had any time to do anything, I wanna pull the damn speaker out, havent' had any time what-so-ever- worked all day today moving a bunch of old x-ray equipment on like 4 hours of sleep, at the doctor's office I LOCKED the keys in the truck, took me 1.5 hrs to get 'em out, took a blood pressure cuff and stuffed it in the door seal and pumped it up, it pushed the door open a bit, I was able to fish in there with a bar to one of the x-ray machines and pop the lock....then teh same truck----spun it out, it's a ram 2500 (24v turbo cumins diesel) & almost went off the road because some ******* hassidic jew from the city cut me off and I had to swerve goin like 65mph) so I was really annoyed & in a shitty mood, then I had to go help somebody else out at their house, I had to take my GTI because insurance pulled my comprehensive insurance on my civic becuase they have to take the pictures to proove it was fixed along with the receipt from the body shop to show I fixed it (hit a deer) - so I can't even drive my civic until I get comprehensive insurance back on it - sitloads of deer here, didn't even make it in the house, got home, shut off my GTI, I fell asleep IN THE DRIVER'S seat NOT RECLINED for THREE hours, woke up at 8:45, realized I told somebody I'd meet 'em at 6:30-6:45, then had to do that ****, grabbed dinner, and got home at like 10:30 to eat dinner...and every day has been packed as hell like this, it's ****** rediculous
So Sorry if I'm unloadin on u guys :-X ****'s been harsh, I've been busy, haven't even seen the inside of the civic until today when I had to move it to get a big azz table in my basement...I think tomorrow I can schedule an appointment for tomorrow for that ******** to take the pictures so I can send the pictures and the receipt off to my insurance company in ****** phoenix AZ (ACross the country) so hopefully they can give me my insurance back but underwriting still has to review it to see if they can give me back comprehensive ('cause if I can't get comprehensive coverage back on it, the car's 2000lbs of a wallet implosion ready to happen, I'll need to sell it) and ****** underwriting will take 2 fukin weeks....it's rediculous
Wow, I'm sorry, I think tomorrow after I get the pictures of my honda taken I can pull the speakers and see what size they are, from what u guys say they're 6 and a half's so I should be able to go to circuity city or something and buy 4 of the same 6 1/2's and they should fit, right? Standard size, not deep...and I'ma buy the speaker harnesses so everything should go suade and I won't have to sodder nething...but u guys said the clips are the same...so if I'm packin 4 6 1/2's for the FRONT that circuit city & crutchfeld said they'd fit, (2 sets of 2) of the same exact speaker, it should fit & screw in fine and with the harness for the front should plug right up, right?
Like I said...sorry if I was comin off like an *******, shitload of stress 'n ****, and I'm not getting paid a lot (or I'm I'm getting paid at the same rate at the bills are coming in) so I've been in a really shitty mood lately and now that I was gonna buy my friend an alarm system for his '94 EX, I think I might want one for my '95 EX, and the alarm pros claim that I can't hook 'em up myself that I need pro installation which I can't drop 180 for both of 'em on installation of crap
Too much **** this week....too much **** this month
SOrry
Old Jul 27, 2006 | 06:44 AM
fcm's Avatar
fcm
Old Fart
No biggy, we all have our shitty days.
As for the alarm, not sure how it works in the states but up here, [Canada] all alarms come with at least one year "manufacturers defect warranty" no matter who installs it, as long as it's purchased at an authorized dealer, and most have a lifetime warranty if purchased and installed at an authorized dealer. 94
Old Jul 27, 2006 | 07:48 AM
B18C_EJ8's Avatar
And WTF does any of this have to do with the keyless entry that's in your thread's title???
Old Jul 27, 2006 | 08:50 AM
Syndacate's Avatar
Default Re: (B18C_EJ8)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B18C_EJ8 &raquo;</TD></TR><TR><TD CLASS="quote">And WTF does any of this have to do with the keyless entry that's in your thread's title??? </TD></TR></TABLE>
Uhh, read the first line in the first post, then look at the link right underneath it...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fcm &raquo;</TD></TR><TR><TD CLASS="quote"> No biggy, we all have our shitty days.
As for the alarm, not sure how it works in the states but up here, [Canada] all alarms come with at least one year "manufacturers defect warranty" no matter who installs it, as long as it's purchased at an authorized dealer, and most have a lifetime warranty if purchased and installed at an authorized dealer. 94 </TD></TR></TABLE>
O
I'm not evne sure if I'ma do this, I might just end up takin him to dinner or something....'cause now I'm evne more pissed off, my insurance company is being ****** ********, don't wanna give me insurance, said that "my car wasn't worth fixing" - who the expletive are they to tell me if I wanna fix it or not...I bought it back, got it fixed....and now they said it wasn't worth fixing ...
If I can't get coverage back on this car, I HAVE TO sell it and buy a new car in like 30 days before I go to college
**** just keeps getting better 'n better....
Old Jul 27, 2006 | 09:01 AM
B18C_EJ8's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote &raquo;</TD></TR><TR><TD CLASS="quote">Uhh, read the first line in the first post, then look at the link right underneath it...</TD></TR></TABLE>
I did. And it says that you need help with keyless, yet your thread mentions nothing about keyless... Maybe I'm missing something???
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote &raquo;</TD></TR><TR><TD CLASS="quote"> Speaker Size/Keyless Entry</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote &raquo;</TD></TR><TR><TD CLASS="quote">so here's the thread, I need some help with keyless entry/alarm:</TD></TR></TABLE>
Old Jul 27, 2006 | 10:22 AM
Syndacate's Avatar
lol, ur not the sharpest knife in the drawer, are you...
"Uhh, read the first line in the first post, then look at the link right underneath it..."
now that u've read the first line....look down a bit...and u'll see a link, u can click that link...and presto, everythin will be explained
Old Jul 27, 2006 | 03:35 PM
fcm's Avatar
fcm
Old Fart
Default Re: (Syndacate)
So did you get the key-less entry system question answered?
I messed the Thread link also, you normally see them like this... https://honda-tech.com/zerothread/1699459 94
Old Jul 28, 2006 | 10:07 AM
Syndacate's Avatar
Default Re: (fcm)
Basically, they told me I need a pro isntall, and the more I think about it, if a thief wants itno a honda, he's getting in, u'll need tons of $$$$$ in security to keep a thief out, and if the thief knows waht he's doing, even that won't stop it...ont like a benz or anythign w/ lazer programmed keys.....so w/ that asside, I move back to the speakers
I pulled the rear today, it was a 5 1/4 speaker, and I don't think a 6 1/2 will fit there....u guys sure a 6 1/2 will fit...because the 5 1/4 fits perfectly, it doesn't look like anything else will fit...help plz
Old Jul 28, 2006 | 05:16 PM
Syndacate's Avatar
bump, blah....nebody else sure it can fit 6 1/2's, b/c it's really small, the 5 1/4's barely fit in the back :-\
You sure u don't have to do some cutting to fit the 6 1/2's?
Old Jul 29, 2006 | 08:26 AM
fcm's Avatar
fcm
Old Fart
If it is a 5.25" speaker the that's all that will fit without custom work, unlike the front 6.5" locations that you can install a set of 5.25" speakers without custom work, 5.25" speaker mounting screw holes are already in the speaker housing along with the 6.5" speaker mounting screw holes. 94
Old Jul 29, 2006 | 11:02 AM
Syndacate's Avatar
Default Re: (fcm)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fcm &raquo;</TD></TR><TR><TD CLASS="quote">If it is a 5.25" speaker the that's all that will fit without custom work, unlike the front 6.5" locations that you can install a set of 5.25" speakers without custom work, 5.25" speaker mounting screw holes are already in the speaker housing along with the 6.5" speaker mounting screw holes. 94 </TD></TR></TABLE>
ya, that's what I thought, so I'm not sure if I wanna go 6.5's in the front and 5.25's in the rear or just 5.25's all the way around :-\
5.25's will be hella cheap b/c u get discounts for buying the same speaker in a pair from CC
Old Jul 29, 2006 | 11:38 AM
fcm's Avatar
fcm
Old Fart
Although normally you would want to go with the bigger speaker, [bigger cone = moves more air = lower f3 point "better bass"] but as long as the 5.25" speaker is "sealed" once mounted, a lot of 5.25" are less then 5" in diameter, [either speaker is bigger then the 5" mounting hole or you make a gasket to seal the speaker] you will have a hard time telling the diff. between the two.
You could make a bigger difference in SQ by installing the 5.25" speakers on custom MDF speaker housings instead of the stock plastic ones, I would be willing to bet, everything being equal, that a 5.25" speaker mounted to custom MDF speaker housing will outperform a 6.5" version of the speaker mounted to the stock plastic housing.
And no, I do not mean a MDF "spacer", custom being the operative word here. 94
cecknight
Audio / Security / Video
Sep 26, 2007 06:25 PM
LSej1
Jul 24, 2007 06:51 AM
94c1v1cex
Apr 15, 2007 02:19 PM
99 civic chick
10
Feb 21, 2004 02:09 PM
