Speaker polarity.
Old Aug 25, 2004 | 12:34 PM
rentacop's Avatar
Default Speaker polarity.
Im installing speakers in my EG hatch...and i have no idea which wire is pos. and which is ground. The speaker sounds the same when its hooked up either way, so does it matter?
Old Aug 25, 2004 | 12:43 PM
keemosaki's Avatar
Default Re: Speaker polarity. (rentacop)
Truthfully.... no not at all. You would want to hook up the right way but sound Will come out either way. I dont believe there is a difference unless there is it a built in crossover or something else (neon light connected) that requires the correct + and -. just see how it sounds... wait... you cant tell the difference. What color wires are they? usually the darker one is the negative (black... brown)
Old Aug 25, 2004 | 03:30 PM
rjr162's Avatar
Default Re: Speaker polarity. (keemosaki)
It doesn't matter to the speaker by its self. What is matters to is the polarity of the overall system. Say you only have the front speakers installed. Now if you hook them both up correctly, then the speakers will both push out at the same time and pull in. This is called in phase. If you reverse one speaker, what happens is while say the drivers speaker is moving out, the passenger speaker in moving in, which is in a sense making the opposite sound wave of the drivers door. What this does is cancel out some sound, most of it being in the bass.
An easy way to tell if you have the wires backwards or not is hook them up (say just the fronts for example, or if you have rears hooked up too just fade to the front). Listen to how the bass sounds. Now balance to the left or right and see if the bass increases or decreases. If it decreases, then you most likely have the "polarity" correct. If it increases when it's only playing from one of the two speakers, and gets quiter as you balance back to the center, then one of the speakers is hooked up reversed in relation to the other speaker.
Now if you just go around and see between the speakers, compairing first the fronts, then the left front and left rear, then both rears, and then the right front and right rear, you should be able to get all the speakers in phase.
Old Aug 25, 2004 | 07:59 PM
fcm's Avatar
fcm
Old Fart
Default Re: Speaker polarity. (rjr162)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rjr162 &raquo;</TD></TR><TR><TD CLASS="quote">It doesn't matter to the speaker by its self. What is matters to is the polarity of the overall system. Say you only have the front speakers installed. Now if you hook them both up correctly, then the speakers will both push out at the same time and pull in. This is called in phase. If you reverse one speaker, what happens is while say the drivers speaker is moving out, the passenger speaker in moving in, which is in a sense making the opposite sound wave of the drivers door. What this does is cancel out some sound, most of it being in the bass.
Now if you just go around and see between the speakers, compairing first the fronts, then the left front and left rear, then both rears, and then the right front and right rear, you should be able to get all the speakers in phase.</TD></TR></TABLE> Dito that 94
Old Aug 26, 2004 | 10:12 PM
eastbay92cx's Avatar
Default Re: Speaker polarity. (fcm)
These guys are correct, but if it makes it easier on you, reds and blues are positives on those cars, and browns and greys are negatives. Good luck
Old Aug 27, 2004 | 05:18 AM
Xsi's Avatar
Xsi
Connect a 9v battery for a brief moment, if the speaker cone moves outward it means the positive battery terminal is connected to the positive speaker terminal.
Old Aug 27, 2004 | 09:12 PM
sceg's Avatar
Default Re: (Xsi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by eastbay92cx &raquo;</TD></TR><TR><TD CLASS="quote">These guys are correct, but if it makes it easier on you, reds and blues are positives on those cars, and browns and greys are negatives. Good luck</TD></TR></TABLE>
yup
Old Aug 28, 2004 | 05:27 PM
Phat_Jax's Avatar
Default Re: (Xsi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Xsi &raquo;</TD></TR><TR><TD CLASS="quote">Connect a 9v battery for a brief moment, if the speaker cone moves outward it means the positive battery terminal is connected to the positive speaker terminal.</TD></TR></TABLE>
The only way to truely know...
Feli
Audio / Security / Video
Feb 28, 2010 06:03 PM
AlphaKennyWun
Jul 9, 2009 06:20 AM
itsJDMyo
10
Jun 13, 2009 04:01 PM
@5200
Mar 18, 2009 08:15 PM
TonyRomo
Aug 7, 2008 12:14 AM
