4 channel amp and sub
Old Aug 27, 2004 | 10:20 PM
pezzy's Avatar
Default 4 channel amp and sub
im goign to get a 4 channel amp that gives 50 rms watts to each speaker..will i need another amp to power a sub that can use 400 watts?
Old Aug 28, 2004 | 03:54 AM
bassisliffe's Avatar
Default Re: 4 channel amp and sub (pezzy)
you may not NEED it
but you sure should WANT a seperate amplifier for your sub!
Old Aug 28, 2004 | 06:29 AM
fcm's Avatar
fcm
Old Fart
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pezzy &raquo;</TD></TR><TR><TD CLASS="quote">im goign to get a 4 channel amp that gives 50 rms watts to each speaker..will i need another amp to power a sub that can use 400 watts?</TD></TR></TABLE> Do you have 4 speakers to drive with the 4ch amp? if so, yes you will need another amp for your sub, if not, if you only have 2 speakers to drive with the 4ch amp, you can bridge two of the 4ch into 1ch and drive the sub off of it, that said 100 watts is not a lot to drive a 400 watt sub, you can also,[if you only have 2 speakers] bridge the 4ch amp into 2ch and use them to drive the speakers, and get a 400 watt sub amp. 94
Old Aug 28, 2004 | 07:16 AM
Default Re: 4 channel amp and sub (fcm)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fcm &raquo;</TD></TR><TR><TD CLASS="quote"> Do you have 4 speakers to drive with the 4ch amp? if so, yes you will need another amp for your sub, if not, if you only have 2 speakers to drive with the 4ch amp, you can bridge two of the 4ch into 1ch and drive the sub off of it, that said 100 watts is not a lot to drive a 400 watt sub, you can also,[if you only have 2 speakers] bridge the 4ch amp into 2ch and use them to drive the speakers, and get a 400 watt sub amp. 94</TD></TR></TABLE>
hey dont get me wrong, i know you know your **** but i must say this
running mids and a sub on a 4 channel amp is possible, but will ONLY sound good if you split the channels on a crossover and tune the bass side differently from the mid/high side
i do this on my 2 chaanel amp with y-splitters, so its not only 4 channel amps that can be used (i have a 2 channel amp that plays 4 speakers perfectly ) so splitting them would be a good idea if you want it to sound good
of course alot of 4 channel amps have high low pass frequency etc etc to tune the 2 channels differently, but imo not many of them work well
seperating the channels on a crossover is like having a seperate amp for bass
Old Aug 28, 2004 | 07:35 AM
rcurley55's Avatar
New User
Default Re: 4 channel amp and sub (bassisliffe)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bassisliffe &raquo;</TD></TR><TR><TD CLASS="quote">
seperating the channels on a crossover is like having a seperate amp for bass </TD></TR></TABLE>
Dude - what the **** have you been smoking.....
BTW, he'd be getting 200W to the sub - assuming it would present a 4 ohm mono load to the amplifer
Old Aug 28, 2004 | 09:34 AM
Default Re: 4 channel amp and sub (rcurley55)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rcurley55 &raquo;</TD></TR><TR><TD CLASS="quote">
crossovers
but seriously, if what i said s garbage im sorry, just what i experience...
Old Aug 28, 2004 | 06:54 PM
fcm's Avatar
fcm
Old Fart
BTW, he'd be getting 200W to the sub - assuming it would present a 4 ohm mono load to the amplifer</TD></TR></TABLE> What? 4x50 watts into 4ohms 2ch bridged =200 watts into 4ohms? 94
Modified by fcm at 5:04 PM 8/29/2004
Old Aug 28, 2004 | 09:20 PM
cd5_2NR's Avatar
yes..or you can buy 1 amp that has 5 channels...4 channels for mids and 1 channel for a sub...
lsvtek
Audio / Security / Video
42
Feb 11, 2007 09:55 PM
technine
15
Jun 15, 2004 08:04 AM
EVIL_AWD
13
Jul 18, 2003 12:14 PM
redteg1
Apr 9, 2002 08:46 PM
