sony xm7557
Old Jul 14, 2004 | 02:13 PM
devilpuppy's Avatar
Default sony xm7557
i have this 5 channel amp
and it only has one connection for a subwoofer, 1 positive and 1 negative
does this mean i can only install one sub??
Old Jul 14, 2004 | 05:28 PM
Hondaaccordvtec's Avatar
Default Re: sony xm7557 (devilpuppy)
What are some more of the specs on the sony 7557 - what does the 5th channel pump out @ 4ohms? Is it 2 ohm stable? If so, what is the wattage rating?
If you can give us this info. we can give you some suggestions. If you want more than 1 sub hooked up, there are some wiring schemes that will allow you do it and still see a 4ohm load on amp
Old Jul 14, 2004 | 05:46 PM
devilpuppy's Avatar
Default Re: sony xm7557 (Hondaaccordvtec)
to be exact...here it is:
http://www.crutchfield.com/S-J...7&s=0
Sony ES XM-7557
75W x 4 + 220W x 1 Car Amplifier
Key Features:
90 watts x 4 + 280 x 1 at 2 ohms
180 watts x 2 + 220 x 1 in bridged mode
subwoofer channel stable to 1 ohm (280 watts RMS)
Old Jul 14, 2004 | 05:56 PM
You could have 2 subs wired up to the 5th channel. If you are saying the sub channel is 1 ohm stable - then just wire both subs in parallel.
Old Jul 14, 2004 | 07:10 PM
devilpuppy's Avatar
does it matter on what subs i get like how much impedance each one is or wat size (10's, 12's)
Old Jul 14, 2004 | 07:19 PM
fcm's Avatar
fcm
Old Fart
You can install as many subs as you want,as long as the load is not lower then 1ohm, 10s,12s,15s,or 18s, [there is a point of diminishing return] 94
Old Jul 14, 2004 | 07:23 PM
EBP_SI's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by devilpuppy &raquo;</TD></TR><TR><TD CLASS="quote">does it matter on what subs i get like how much impedance each one is or wat size (10's, 12's)</TD></TR></TABLE>
The actual size of the driver doenst matter. The impedence is extremely important though. if its one ohm stable as you say, you'll need a pair of 2ohm SVC subs or a pair of DVC subs with 4 ohm VC's.
Old Jul 15, 2004 | 06:29 AM
devilpuppy's Avatar
Default Re: sony xm7557 (EBP_SI)
so if i get the ohms on teh subs....ur sayin i can connect as many as i want to that ONE channel.....there is only one + and one -
thats it!!
Old Jul 15, 2004 | 09:11 AM
itr_dc2's Avatar
Yeah, you can hook them all up to one channel. it's like having a mono amp. Only one output. That's why as others stated, at 1 channel, you can only run a DVC or 2 SVC to make it stable at 2 or 4 depending if you wire in series or parallel.
Keep this in mind, the RMS each sub needs to be driven
Old Jul 18, 2004 | 07:14 PM
devilpuppy's Avatar
Default Re: sony xm7557 (itr_dc2)
okay...i got 2 12's in a sealed box...how do i go about connecting them?
do i take teh positve from each sub and join them together and put them in teh positive and take both negatives and connect the together then put to the negative connection on teh amp?
remeber this amp has only 1 subwoofer output channel....only ONE + and -
Old Jul 19, 2004 | 09:27 AM
fcm's Avatar
fcm
Old Fart
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by itr_dc2 &raquo;</TD></TR><TR><TD CLASS="quote">Yeah, you can hook them all up to one channel. it's like having a mono amp. Only one output. That's why as others stated, at 1 channel, you can only run a DVC or 2 SVC to make it stable at 2 or 4 depending if you wire in series or parallel.
Keep this in mind, the RMS each sub needs to be driven</TD></TR></TABLE>
No, you can run as many subs as you want, and as EBP_SI said the impedence is what is important, [ what the amp sees as the load]
what kind of subs do you have devilpuppy? one voice coil or two? and what is the impedence of the voice coils? 94
Old Jul 19, 2004 | 03:19 PM
devilpuppy's Avatar
Default Re: sony xm7557 (fcm)
i have 2 of these:
Pioneer TS-W304C
12" 4-ohm Component Subwoofer
http://www.crutchfield.com/S-k...W304C
Old Jul 19, 2004 | 03:32 PM
bassisliffe's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by devilpuppy &raquo;</TD></TR><TR><TD CLASS="quote">so if i get the ohms on teh subs....ur sayin i can connect as many as i want to that ONE channel.....there is only one + and one -
thats it!!</TD></TR></TABLE>
if you put alot of subs on that sony amp you might not hear any bass
Old Jul 19, 2004 | 04:46 PM
fcm's Avatar
fcm
Old Fart
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by devilpuppy &raquo;</TD></TR><TR><TD CLASS="quote">i have 2 of these:
Pioneer TS-W304C
http://www.crutchfield.com/S-k...W304C</TD></TR></TABLE>
wire the subs in parallel, pos. to pos. neg. to neg. and then to the amp.<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bassisliffe &raquo;</TD></TR><TR><TD CLASS="quote">
if you put alot of subs on that sony amp you might not hear any bass </TD></TR></TABLE>
Yea there is a point of deminishing return. 94
Old Jul 19, 2004 | 05:33 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fcm &raquo;</TD></TR><TR><TD CLASS="quote">
simple as that
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fcm &raquo;</TD></TR><TR><TD CLASS="quote"> Yea there is a point of deminishing return. 94</TD></TR></TABLE>
i think that line is already crossed
a 5 channel sony amp
thats like something out of my nightmares
does the sub part use different rcas? so you could tune it as a seperate channel??
Old Jul 19, 2004 | 06:50 PM
devilpuppy's Avatar
Default Re: sony xm7557 (bassisliffe)
yea..the deck has its own sub control....which means it has its own rcas, right?
Old Aug 2, 2004 | 03:13 PM
fcm's Avatar
fcm
Old Fart
Comon bass you don't have nightmares, you try them 94
Matthew_zero
Audio / Security / Video
Mar 7, 2008 11:07 AM
Accord1234
Feb 14, 2008 05:05 AM
Chi
Mar 7, 2007 10:09 AM
Mazzazx51
May 19, 2004 05:55 AM
vtec-outlaw
Feb 4, 2002 12:45 PM
