rca's - front/rear
Old Aug 2, 2004 | 11:16 AM
devilpuppy's Avatar
Default rca's - front/rear
i have a 5 channel sony amp and all my door speakers are connected to the amp. I noticed this is what happens:
if i unplugged the front rca's from the amp....only the rear speakers work
but if i unplug the rear rca's from the amp....all 4 speakers (front and rear) still work
is that how it is suppose to be? or is something wrong?
Old Aug 2, 2004 | 12:27 PM
fcm's Avatar
fcm
Old Fart
Default Re: rca's - front/rear (devilpuppy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by devilpuppy &raquo;</TD></TR><TR><TD CLASS="quote">i have a 5 channel sony amp and all my door speakers are connected to the amp. I noticed this is what happens:
is that how it is suppose to be? or is something wrong?</TD></TR></TABLE> Input switch on amp is in wrong position . 94
Old Aug 2, 2004 | 12:37 PM
devilpuppy's Avatar
Default Re: rca's - front/rear (fcm)
what input switch?
Old Aug 2, 2004 | 02:34 PM
fcm's Avatar
fcm
Old Fart
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by devilpuppy &raquo;</TD></TR><TR><TD CLASS="quote">what input switch? </TD></TR></TABLE> Is there not a switch on the amp that says input select, I know that Alpine made an amp that input select was automatic ,I don't know of any others, try this, fade front to rear, does it work? if so, the switching is automatic, if not, you have a problem, what inputs on the amp are the front RCAs plugged into? on some amps there is a switch to select how the 5th ch. gets its sig. ext. with a set of RCAs or internally, if switched to internal and front RCAs are plugged into 5th ch. BINGO
hope this helps. 94
Old Aug 2, 2004 | 02:55 PM
devilpuppy's Avatar
i dont think there is an input switch....but the fader from rear to front works and same with the balance...left to right
its the sony 5 channel amp. i have one set of rca's to the front one set to the rear and the last set of rca's to the sub channel
Old Aug 2, 2004 | 03:50 PM
fcm's Avatar
fcm
Old Fart
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by devilpuppy &raquo;</TD></TR><TR><TD CLASS="quote">i dont think there is an input switch....but the fader from rear to front works and same with the balance...left to right
its the sony 5 channel amp. i have one set of rca's to the front one set to the rear and the last set of rca's to the sub channel</TD></TR></TABLE> If fader works switching is automatic and you don't have a problem. 94
CoolRedXylophone
Audio / Security / Video
Aug 28, 2007 08:37 AM
doggworld1233
Jan 15, 2007 08:37 PM
hu
Feb 3, 2006 05:22 PM
Mrfeee1
Apr 18, 2005 09:36 AM
mr_mbuna
Sep 8, 2002 12:45 PM
