short circuit problem? please help..
Old Apr 5, 2005 | 07:49 PM
LSRracing95's Avatar
Default short circuit problem? please help..
i have a 95 acura integra and i have a system in it
a few weeks ago i went to my nearest audio store, sound city in denville new jersey..
i was getting my kick panel speakers warrentied and when they took them out.. i went to play my music again(which all the speakers are amplified with a 5 channel mtx amplifer) and nothing happened.. it then started to blow the main fuse to the power wire line to the amplifier.. what do you think the problem could be because i have begun to un-wire the car and i havent found any signs of where a short circuit would be happening.. is it even short-circuiting? and if so how would i be able to tell and locate the problem.. thank you very much...
ryan
Old Apr 6, 2005 | 08:49 AM
matt_in_sd's Avatar
Default Re: short circuit problem? please help.. (LSRracing95)
Disconect all your speaker wires from the amp and then see if it powers up. If you still blow the fuse, and the amp is the only thing on this fuse then the amp is fried. If you have a ohm meter test each set of speaker wires for a short.
Old Apr 6, 2005 | 09:32 AM
fcm's Avatar
fcm
Old Fart
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LSRracing95 &raquo;</TD></TR><TR><TD CLASS="quote">i have a 95 acura integra and i have a system in it
ryan</TD></TR></TABLE>Was it working before you had sound city remove the speakes, and not after you got the car back, [without the kick panel speakers]? if so, did sound city forget to cap off the speaker wires, and are they shorting out?
As matt_in_sd said......
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by matt_in_sd &raquo;</TD></TR><TR><TD CLASS="quote">Disconect all your speaker wires from the amp and then see if it powers up. If you still blow the fuse, and the amp is the only thing on this fuse then the amp is fried. If you have a ohm meter test each set of speaker wires for a short.</TD></TR></TABLE> Do it, do not keep replacing the fuse and trying it, you can do damage or more damage to the amp. 94
Old Apr 6, 2005 | 06:04 PM
Default Re: short circuit problem? please help.. (fcm)
thanks for the help, im working on it tomorrow i have everything disconnected because i have been having problems with engine whine too and i cant figure that out.. if you know anything about that as well please help.. and im hoping these amplifiers are not fried........ keep postin thanks guys
Old Apr 7, 2005 | 09:14 AM
fcm's Avatar
fcm
Old Fart
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LSRracing95 &raquo;</TD></TR><TR><TD CLASS="quote">thanks for the help, im working on it tomorrow i have everything disconnected because i have been having problems with engine whine too and i cant figure that out.. if you know anything about that as well please help.. and im hoping these amplifiers are not fried........ keep postin thanks guys </TD></TR></TABLE>"Engine whine" is almost always caused by wiring problems, although can be caused by a mismatch of componants in the system HUs, Sig. Pro. and or Amps, but most likely, wiring 94
Old Apr 7, 2005 | 06:47 PM
hey, thanks for the help fcm.. i worked on the whole thing today.. found out that the amplifer was blown but can be fixed.. i bought a new amplifer.. wired it all.. i just have to wire up a remote wire relay cause i have 3 amps now instead of 2 and i have to put my power cap in and then tune it and its finished.. thanks again for the help!
biggjimmy7
Audio / Security / Video
Aug 2, 2006 04:50 PM
jli18
18
Jul 25, 2006 07:54 PM
PearlBlueType-S
Mar 24, 2006 03:37 PM
E M P I R E
Feb 8, 2004 08:50 AM
Bklyn TSi
Nov 6, 2001 11:11 AM
