This setup sound ok?
Old Jul 13, 2006 | 02:17 AM
OMG WTF's Avatar
Default This setup sound ok?
Im planning on getting a very simple stereo setup for my 88 CRX. I dont listen to music with excessive bass, i just want clean, crisp, cheap and something lightweight. How does this sound...
- Alpine CDA-9856 w/ ipod adapter
- Alpine Type-S 6.5" component SPS171A for the front
- replica JDM basstubes for the rear speaker location
- JL Audio 6W0 subwoofers mounted in the basstubes (if they fit, otherwise i'd get some cheap subwoofer from a electronic supply store)
- Alpine 4x40watt amp MRP-F250 (no particular reason i picked this one)
Basically components in front, subs in rear. 2 channels from the amp going to the front speakers, and the other 2 channels bridged to power the rear subs. A subwoofer box is completely out of the question. The setup needs to be discrete, light, sound decent, and cheap. Im not to keen on car audio equipment so any suggestions would be appreciated, just keep it around the same price range. Thank you.
Old Jul 13, 2006 | 06:29 AM
fcm's Avatar
fcm
Old Fart
Default Re: This setup sound ok? (zclee.com)
Drop the JL subs, use Alpine SPX-17MB... http://www.alpine-usa.com/en/p...-17MB and more power, the MRP-F450... http://www.alpine-usa.com/en/p...-F450
If you want to go with the JL Audio 6W0s or even the Alpines you will need more then 2x40W RMS of power to run them, clean accurate sound is dependent on having enough power, something like a JL 300/4... http://mobile.jlaudio.com/prod...d=254 would be a better bet then the Alpine amp. 94
Old Jul 13, 2006 | 06:51 PM
OMG WTF's Avatar
anyone else?
Old Jul 13, 2006 | 07:12 PM
SloCrxDx91's Avatar
so what kind of amp are you running the sub with? JL is overpriced if you want a small system like that get a type r from alpine or something cheaper
Old Jul 13, 2006 | 07:49 PM
OMG WTF's Avatar
have you read my post at all?
Old Jul 13, 2006 | 11:00 PM
wrx-killer-Sti-eater's Avatar
From: 99 probs but a stolen car aint 1, ca, cerritos/fullerton
Default Re: This setup sound ok? (fcm)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fcm &raquo;</TD></TR><TR><TD CLASS="quote">Drop the JL subs, use Alpine SPX-17MB... http://www.alpine-usa.com/en/p...-17MB and more power, the MRP-F450... http://www.alpine-usa.com/en/p...-F450
If you want to go with the JL Audio 6W0s or even the Alpines you will need more then 2x40W RMS of power to run them, clean accurate sound is dependent on having enough power, something like a JL 300/4... http://mobile.jlaudio.com/prod...d=254 would be a better bet then the Alpine amp. 94</TD></TR></TABLE>
That was the best advice.
Old Jul 13, 2006 | 11:09 PM
MilanoCivic97's Avatar
Default Re: This setup sound ok? (wrx-killer-Sti eater)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by wrx-killer-Sti eater &raquo;</TD></TR><TR><TD CLASS="quote">
That was the best advice. </TD></TR></TABLE>
x2
Old Jul 13, 2006 | 11:16 PM
OMG WTF's Avatar
ok i guess i'll try that but you guys really think a mid-bass would sound better than a subwoofer?
Old Jul 14, 2006 | 06:07 AM
fcm's Avatar
fcm
Old Fart
Default Re: (zclee.com)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by zclee.com &raquo;</TD></TR><TR><TD CLASS="quote">ok i guess i'll try that but you guys really think a mid-bass would sound better than a subwoofer?</TD></TR></TABLE> They will sound better, unless you are prepared to install the JL subs into cabinets, [sub box] they need 0.175 cuft for volume "net" each.
There is more then enough room in the sides, [stock rear speaker locations] for fiberglass cabinets that size... http://mobile.jlaudio.com/prod...id=23
However I am not sure there is the 3.5" of mounting depth that the sub needs, [by the time you add the thickness of the box and clearance from the outside skin.
I have a set of Eclipse 6.5" 2ways, [tweeter disabled] mounted in custom MDF and fiberglass cabinets, [0.5 cuft net volume] in the stock rear speaker locations, in my 94 LS, same speakers mounted in the front, [tweeters working] all are running off an Alpine HU, I get very good SQ including bass response, and the system is more then loud enough for me. 94
Old Jul 14, 2006 | 08:55 AM
OMG WTF's Avatar
Default Re: (fcm)
These are the JDM CRX replica basstubes...
im not sure of the exact volume but do they look like they would be big enough?
but on the other hand im not even sure the JL 6W0s will fit because of the magnet...
BTW thanks for the advise.
Modified by zclee.com at 10:05 AM 7/14/2006
Old Jul 14, 2006 | 02:22 PM
fcm's Avatar
fcm
Old Fart
Hard to tell how deep they are, but you may be right, they may not fit, you will need 3.5" of mounting depth and a little over 4.5", [diameter] of clearance for the magnet... http://mobile.jlaudio.com/prod...id=23
The Alpine is just 2.8" mounting depth and magnet is only 3.7" in diameter.
Also the mounting hole diameter is 5.2" on the Alpine and 5.625" on the JL. 94
jrodrick4
Audio / Security / Video
Dec 3, 2009 05:55 PM
zerovandez
16
Dec 6, 2006 05:57 PM
miksew
15
Jul 28, 2005 09:31 AM
SSBP DC2
26
Apr 17, 2003 07:53 AM
AllMotorITR
Sep 19, 2002 07:56 PM
