Setting your amp to 2 ohms
In nearly all cases, it depends solely on the imdependace of your subs, # of subs, and if they are single or dual voice coil.
EX. IF you have one sub, and it is dual 4 ohm, you would run it parallel (++, - - ) that would produce 2 ohms, then just hook your + and - into your amp, and it will be @ 2 ohms
the info 94lsboost gave you is correct but i thought i'd just help out and add that there is a sub wiring tutorial at jl's website. you can reach it at http://jlaudio.com/tutorials/wiring/index.html. there are even some nice pics.
well You can use any amp on "normal" speakers. You can even wire them in parallel or series to achieve a different imdependace. However if you run regular speakers @ 2 ohms, some cant handle it (heat up), and even if they do, they usually don't sound that great. They can be ran on a larger amp @ 8 ohms to reduce the power output tho, safely I might add.
Yeah that's what I was unsure about. On my amp it says it can run 2ohms @ 100 watts X 4 channels. Which would work perfectly with my rears and my new fronts, but when I actually looked at the specs on my speakers all of them are reccommend at 4 ohms. I was just wondering cause at 4 ohms my amp only puts out 75 watts X 4 channels, so I just wanted to get a little more juice out of the thing without buying a new amp.
Dave
Dave
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 94lsboost »</TD></TR><TR><TD CLASS="quote">well You can use any amp on "normal" speakers. You can even wire them in parallel or series to achieve a different imdependace. However if you run regular speakers @ 2 ohms, some cant handle it (heat up), and even if they do, they usually don't sound that great.</TD></TR></TABLE>
I don't know if you are speaking about the amp or the speaker heating up - yes the amplifier will typically make more heat at 2 ohm then it will at 4 ohm but I doubt anyone could hear a degredation in sound based on the impedance you run the amplifier at. The increase in power will clearly off-set any small increase in distortion. Take a look at the impedance curve of any of your speakers and you will see that speakers are rated at a nominal impedance, and the impedance of the driver is constantly changing depending on frequency.
My mids and midbasses are 2 ohm drivers and they sound great!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rcurley55 »</TD></TR><TR><TD CLASS="quote">
My mids and midbasses are 2 ohm drivers and they sound great!</TD></TR></TABLE>
That is sweet, I have a friend doing it (old school fosgate amps) on JL mids/tweets, and after playing for a while, if you have the windows up in his truck, you can smell the mids start to heat up. They also lose SQ as they go. I have saw this a few times, however I also know of people who run them @ 2 ohms effectively. I suppose it all depends on your speakers, amp, setup....etc, as with anything else.
You can also check out this site as well: http://www.rockfordfosgate.com/rftech/wiringwizard/
Jonathan_ED3
Audio / Security / Video
11
Jul 9, 2003 10:33 AM
