security: relays....need quick answer
Old Nov 5, 2006 | 02:02 PM
SoullessJapaneseMachine's Avatar
Default security: relays....need quick answer
are all relays the same?
i have a bunch left over from when i pulled the fuse box from my vw golf and several of them have the same diagram drawn on them..the 30, 85,86,87 terminals
this is for a kill switch im trying to install
would it be wise to use them?
Old Nov 5, 2006 | 02:54 PM
CarbonizedDX's Avatar
Default Re: security: relays....need quick answer (SoullessJapaneseMachine)
Relays are all the same in function, but the physical lay out of the pins and such isn't always the same. As long as you know your coil pins (85 and 86) and your switch pins (30 to 87A{off}/87{on}) than you can wire it up.
Old Nov 5, 2006 | 02:58 PM
wrx-killer-Sti-eater's Avatar
From: 99 probs but a stolen car aint 1, ca, cerritos/fullerton
Default Re: security: relays....need quick answer (CarbonizedDX)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CarbonizedDX &raquo;</TD></TR><TR><TD CLASS="quote">Relays are all the same in function, but the physical lay out of the pins and such isn't always the same. As long as you know your coil pins (85 and 86) and your switch pins (30 to 87A{off}/87{on}) than you can wire it up.</TD></TR></TABLE>
6genocide6
Nov 28, 2024 03:30 AM
blackrag
10
Jun 27, 2007 04:19 PM
JCracer723
Jun 25, 2006 06:03 PM
GetawayInMoscow
Audio / Security / Video
Apr 7, 2006 12:02 PM
Dr Juice
Sep 20, 2004 01:19 PM
