Hardware need'd for kill switch
Old Sep 20, 2004 | 05:52 AM
Dr Juice's Avatar
Default Hardware need'd for kill switch
I guess this falls under security, but, i know HOW to put a killswitch in on my EG, but i dont know is what spec's on the wire/switch/fuse/led. What im going to try and do is run an LED off my kill switch so i know if its on or off. I heard i need to run a 25amp fuse and switch, but not positive, also, what guage wire is best. And what specs on the LED do i need and do i need resisters too? THanks for the help fella's
Old Sep 20, 2004 | 07:00 AM
audioroach's Avatar
Default Re: Hardware need'd for kill switch (Dr Juice)
What is needed is a 30 amp SPDT ( single pole double throw) relay
a regular switch ( a micro will do fine) a lil imagination and there you go.
Use a Bosche/ P&B relay..something with a very good build quality
because it will LAST!!! One of my cars immobilizer circuitry is well
over 10 years old and it still works flawlessly
Once you know how the relay works ( think of it as a switch ) then the world
is yours.
Old Sep 20, 2004 | 07:07 AM
fcm's Avatar
fcm
Old Fart
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dr Juice &raquo;</TD></TR><TR><TD CLASS="quote">I guess this falls under security, but, i know HOW to put a killswitch in on my EG, but i dont know is what spec's on the wire/switch/fuse/led. What im going to try and do is run an LED off my kill switch so i know if its on or off. I heard i need to run a 25amp fuse and switch, but not positive, also, what guage wire is best. And what specs on the LED do i need and do i need resisters too? THanks for the help fella's</TD></TR></TABLE> Need more info, what are you "killing".
If you get this, you can do most anything
1- 1/4 amp SPST switch
2- 20/30 amp 12v DPDT relay,[may be easier to get 4PDT relay]
3- 12v flashing or nonflashing LED
I don't see a need for fuse, as anything you are "killing" will be fused. 94
Old Sep 20, 2004 | 07:19 AM
Dr Juice's Avatar
Default Re: Hardware need'd for kill switch (fcm)
I am putting a switch in the postive wire of the fuel pump. Im talking about the fuel pump fuse because i am adding a led to the circuit. And how would i wire in the relay.
Old Sep 20, 2004 | 08:21 AM
Dr Juice's Avatar
anyone care to sketch a diagram real quick, cuase i know almost nothing about relays
Old Sep 20, 2004 | 08:32 AM
fcm's Avatar
fcm
Old Fart
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dr Juice &raquo;</TD></TR><TR><TD CLASS="quote">I am putting a switch in the postive wire of the fuel pump. Im talking about the fuel pump fuse because i am adding a led to the circuit. And how would i wire in the relay. </TD></TR></TABLE>If all you are doing is cutting power to fuel pump, all you need is the switch, and I would cut the trigger for fuel pump relay, and a 12v flashing LED can be installed by wiring the red to a 12v constant and the black,[or blue depending on LED] to an acc., led will come on when ign. is turned off, or if you only want the LED to come on when the switch is "open" for the fuel pump, use a DPDT switch, use one pole to open the fuel pump line and the other to close the LEDs acc. line 94
Old Sep 20, 2004 | 08:35 AM
Dr Juice's Avatar
I think i got it, but will let you know when i run into probs wiring it up, thanks for the help
Old Sep 20, 2004 | 01:19 PM
fcm's Avatar
fcm
Old Fart
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dr Juice &raquo;</TD></TR><TR><TD CLASS="quote">I think i got it, but will let you know when i run into probs wiring it up, thanks for the help</TD></TR></TABLE> OK, good luck, IM me if you need help 94
thundernoodle
Audio / Security / Video
15
Aug 6, 2010 06:05 AM
socalrex88
Mar 2, 2008 05:31 PM
eL_cArLos
Feb 20, 2008 06:19 PM
tub_sephiroth
May 9, 2007 07:35 PM
TurboTurtleGSR
Jan 17, 2003 09:04 PM
