Security Kill Switch Question
Old May 22, 2005 | 10:23 PM
white_98_gsr's Avatar
Default Security Kill Switch Question
I have an 98 Integra,
Is there any way to wire the cruise control switch as a kill switch, say for the starter or to the clutch, but at the same time retain the use of cruise control while driving?
I searched and only found info on using the switch if cruise control is no longer in the car.
thanks in advance
Old May 23, 2005 | 04:53 PM
Default Re: Security Kill Switch Question (white_98_gsr)
bump
Old May 23, 2005 | 05:14 PM
o_O's Avatar
o_O
hmm, not a 100% sure but i don't think you can keep the cruise control functionalty because you will have to modify the switch to turn it into a kill switch......
Old May 23, 2005 | 05:49 PM
Loccusst's Avatar
Just install a kill switch elsewhere. You can turn the cigarette lighter/12 volt source into one.
Old May 23, 2005 | 06:34 PM
suspendedHatch's Avatar
Default Re: (Loccusst)
http://www.the12volt.com/relays/page2.asp
use the last diagram. you'll have to adapt it a little cuz its meant for using a horn or other momentary switch.
Old May 25, 2005 | 10:08 PM
Default Re: (suspendedHatch)
so has no one actually done this before?
Old May 26, 2005 | 08:17 AM
Default Re: (white_98_gsr)
People use the AC button for nitrous.
If you find a switch that has two contacts, and it's not momentary, then just tap into the wires and use diodes so you don't feedback into the other circuit. Cruise control I believe is a momentary switch that uses a relay to latch on and off, but I'm not too sure.
Old May 26, 2005 | 09:47 AM
fcm's Avatar
fcm
Old Fart
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by white_98_gsr &raquo;</TD></TR><TR><TD CLASS="quote">so has no one actually done this before?</TD></TR></TABLE> It can be done, but it's a momentary switch, so the relay has to be wired as normally open, so when you hold the CC switch it closes the relay, [on the starter wire] and lets you start the car. 94
Old May 26, 2005 | 10:37 PM
Default Re: (fcm)
bump
Old May 29, 2005 | 06:45 PM
night time bump
johnlvs2run
59
Nov 7, 2014 11:48 AM
PURPLERANGER
Sep 2, 2013 08:50 AM
amb4081
May 12, 2006 10:18 AM
honda_joe
Jun 12, 2003 10:09 PM
