Security Kill Switch Question
I have an 98 Integra,
Is there any way to wire the cruise control switch as a kill switch, say for the starter or to the clutch, but at the same time retain the use of cruise control while driving?
I searched and only found info on using the switch if cruise control is no longer in the car.
thanks in advance
thanks in advance
http://www.the12volt.com/relays/page2.asp
use the last diagram. you'll have to adapt it a little cuz its meant for using a horn or other momentary switch.
People use the AC button for nitrous.
If you find a switch that has two contacts, and it's not momentary, then just tap into the wires and use diodes so you don't feedback into the other circuit. Cruise control I believe is a momentary switch that uses a relay to latch on and off, but I'm not too sure.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by white_98_gsr »</TD></TR><TR><TD CLASS="quote">so has no one actually done this before?</TD></TR></TABLE> It can be done, but it's a momentary switch, so the relay has to be wired as normally open, so when you hold the CC switch it closes the relay, [on the starter wire] and lets you start the car.
94
94
johnlvs2run
59
Nov 7, 2014 11:48 AM
