remote wire?? (searched) help
Old Jun 11, 2006 | 11:05 AM
xtegb16x's Avatar
Default remote wire?? (searched) help
i am currently connecting a system in my yukon and i am coneecting it with the factory stereo i already have the high and low box for the rca's but how do i get the remote? thanx in advance
Old Jun 11, 2006 | 11:43 AM
STK B16's Avatar
Default Re: remote wire?? (searched) help (xtegb16x)
what year Yukon is it? 2003 and up it is the PINK wire at the radio harness.. 2000-2002 is Orange
Old Jun 11, 2006 | 11:56 AM
B16CivicEX's Avatar
u can make your own remote, Any key hot, just use a 12v test light
Old Jun 11, 2006 | 01:50 PM
xtegb16x's Avatar
Default Re: (AirForceB16)
yea but i think ima go with the PINK one thanx and by the way would you actually know that speaker output colors, so i dont have to buy the wire harness??
Old Jun 11, 2006 | 10:30 PM
siggy833's Avatar
Default Re: remote wire?? (STK B16)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by STK B16 &raquo;</TD></TR><TR><TD CLASS="quote">what year Yukon is it? 2003 and up it is the PINK wire at the radio harness.. 2000-2002 is Orange
Actually you need to use the ignition wire for a remote turn-on, not a constant 12v source. The Pink and Orange wires are the constants. The ignition wire is Dark Green.
Old Jun 11, 2006 | 10:45 PM
xtegb16x's Avatar
Default Re: remote wire?? (siggy833)
is there any way you guys can get me the wiring diagram! ive searched google for hours man plz help
Old Jun 12, 2006 | 09:04 AM
siggy833's Avatar
Default Re: remote wire?? (xtegb16x)
You still have not specified the year of your Yukon! We need that to give you correct wire color info...
Old Jun 12, 2006 | 12:57 PM
fcm's Avatar
fcm
Old Fart
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by siggy833 &raquo;</TD></TR><TR><TD CLASS="quote">You still have not specified the year of your Yukon! We need that to give you correct wire color info... </TD></TR></TABLE> Ditto the above. 94
Old Jun 12, 2006 | 07:41 PM
bigsubs's Avatar
tap that wire into the fuse box on a fuse controlled by the ignition Iwouldn't tap any thing behind the radio cause if your under warranty the dealership will def. know and will give you a hard time on electrical repairs!!!
Old Jun 12, 2006 | 10:05 PM
STK B16's Avatar
2000 yukon wires
LF speaker + tan -grey
LR speaker +lt.green - dk.Green
LR speaker + brown - Yellow
RR spakers +blue - lt.blue
12volts constant-- orange
accessroy switch - dk. green.
ground - Black
Illumination -brown
factory amp turn on Orange
Old Jun 14, 2006 | 10:01 AM
xtegb16x's Avatar
oo im sorry i havent been around my comp alot but, its a 03 yukon!
Old Jun 14, 2006 | 12:27 PM
siggy833's Avatar
Ok here is the info you wanted for your Yukon:
Radio 12v
orange
radio harness
Radio Ground black/white - radio harness
Radio Ignition Class 2 Serial Data = This means that the actual ignition for your radio is powered by a very low resistance and not the typical 12volts. You will either have to purchase an adapter for this or run a fused wire to an ignition source at the steering column.
Radio Illumination N/A
Factory Amp Turn-on pink + radio harness
Power Antenna dk. green + radio harness
LF Speaker +/- tan - gray +,- radio harness
RF Speaker +/- lt. green - green +,- radio harness
LR Speaker +/- brown - yellow +,- radio harness
RR Speaker +/- blue - lt. blue +,- radio harness
Old Jun 14, 2006 | 12:34 PM
xtegb16x's Avatar
Default Re: (siggy833)
okay thanx aloott ima get right to it now!
Old Jun 14, 2006 | 05:40 PM
JSPECSIR's Avatar
Default Re: (xtegb16x)
does your yukon have a bose system, and if so are you hooking up a sub amp to it?
D16Z6racing
Audio / Security / Video
Mar 21, 2007 05:56 AM
chamoru
Aug 3, 2005 05:32 PM
JDMlyfestyle
19
Feb 4, 2005 07:51 PM
redman223
Jul 10, 2004 07:34 AM
