sound deadening problem
Old Jun 11, 2006 | 01:09 AM
thejacka's Avatar
Default sound deadening problem
Before today, only my trunk lid was deadened (with dynamat extreme). It sounded fine, I even felt a bit more bass in the car, but the rattles were still there. I've had Damplifier around for a week now and I decided to get started. Well it took me about an hour just to do the inside (trunk side) of the rear deck. Afterwards, I turned my subwoofers on to check the progress of my deadening, and the effect seemed to reverse. I felt less bass in the car than I did prior to deadening the rear deck. There seemed to be more bass outside my car than inside.. which is NOT what I wanted at all, and the rattles either stayed the same or got worse. I don't know what happened and if doing the sides and floor will help. But there are holes on the rear deck that I just covered instead of leaving them. Anyone know the problem or have any input?
Old Jun 11, 2006 | 09:48 AM
02 accord's Avatar
Default Re: sound deadening problem (thejacka)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by thejacka &raquo;</TD></TR><TR><TD CLASS="quote">Anyone know the problem</TD></TR></TABLE>
Yea. You covered up the holes in the deck. I noticed the opposite when I removed my 6x9s. The bass was much louder with the 6x9 holes in the deck than with speakers blocking them.
Old Jun 12, 2006 | 01:06 PM
LudemanDan's Avatar
I'd imagine if the rattles got worse, it's because you now have to turn the volume higher to get the same amount of spl to your ears.
Old Jun 12, 2006 | 01:40 PM
hb420's Avatar
put strips of carpet between the plastic panels and whatevever there attached to.
Old Jun 14, 2006 | 07:46 PM
Znypar's Avatar
ummm, where exactly are the rattles?
mr_mbuna
Audio / Security / Video
19
Jun 12, 2012 03:39 AM
marshall81
Honda Civic (2006 - 2015)
Feb 14, 2007 02:43 PM
Nocal E32M
Suspension & Brakes
Oct 2, 2006 08:56 PM
civic_speed99
Oct 10, 2004 09:36 PM
