Remote Start Problem
Old Mar 26, 2009 | 05:02 PM
  #26
Mikal92's Avatar
Default Re: Remote Start Problem
I don't have a hood pin can I just ground it for it to work. While I wait for it to come in
Old Mar 27, 2009 | 06:21 AM
  #27
fcm's Avatar
fcm
Old Fart
Do not ground hood pin lead, it is what the hood pin will do when hood is open, preventing the remote start from working, [safety feature] if that lead is grounded, it is what is keeping the remote start function from working, disconnect the lead and isolate it. 94
Old Mar 28, 2009 | 03:30 PM
  #28
Mikal92's Avatar
So far I have connected. Red = Main power. I have this connected to White the 12v constant under the dash.
Pink = Ignition output. I have this connected to the black wire with yellow stripe. Pink = Ignition 2. I have this connected to nothing. Orange = Accessory output. I have this connected to the Yellow wire near the steering wheel column. Purple = Starter. I have this connected to the black wire with a white stripe. Blue/White = bypass output. I don't have this connected to anything. Grey/Black = Diesel wait to start bulb. I don't have this connected.
Black//White= Neural Safety Switch Input. I have this grounded. Purple/White = Tach Wire Input. to the blue wire near the firewall on the driver side. And I have wired up the starter kill 30 to starter wire ignition switch side. 87a to starter wire motor side and 85 to starter wire ignition side. and 86 to alarm orange wire. Did I go wrong somewhere?
Old Mar 29, 2009 | 06:30 AM
  #29
fcm's Avatar
fcm
Old Fart
The above wiring is correct, but...
Your sure the starter output, [purple] is on the correct side of starter cut relay, [starter motor side]?
Your sure your brake lead, [brown] is connected to the correct side of brake switch, [hot when brake is stepped on]?
How about the trunk pin input, [black] what have you done with it?
Does the alarm work properly?
What exactly happens when you press the remote start button on the remote? 94
Old Mar 29, 2009 | 01:23 PM
  #30
Mikal92's Avatar
Purple is connected to the black with white stripe on motor side. I have the brake connected to the brake wire right at the harness above the brake pedal. And I have the trunk connected to the trunk pin the green wire.
Old Mar 30, 2009 | 11:21 AM
  #31
fcm's Avatar
fcm
Old Fart
Have you checked to make sure brake lead is connected to the proper lead, 12V+ only when brake is stepped on?
Asked but not answered... What exactly happens when you press the remote start button on the remote?
Old Mar 30, 2009 | 02:24 PM
  #32
Mikal92's Avatar
O sorry! It doesn't do anything.
Old Mar 30, 2009 | 04:45 PM
  #33
fcm's Avatar
fcm
Old Fart
Did you try programing the remotes?
Does the alarm work?
You are pressing star,[*] for 0.5 sec., [press and release] then within 2 sec., pressing unlock for 0.5 sec., [press and release] and waiting 6 sec. for remote start to engage, right? 94
Old Mar 30, 2009 | 08:02 PM
  #34
Mikal92's Avatar
I programmed the remote the alarm does work the siren goes off doors lock, unlock. I did the way to remote install and it didn't start. My uncle owns an auto body shop and knows an installer and told asked him to come check it out for me. I'll let you know what he says. Thanks for all your help.
socallmechris
Audio / Security / Video
Jan 20, 2008 08:54 AM
Synthead
Sep 3, 2005 11:16 PM
b16_madman
12
Jul 28, 2004 05:39 PM
